Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 06-22-2009, 12:56 PM
integerspin is on a distinguished road
two motors off a vfd?
Would it be possible to run my lubrication system[10W motor continously run] and the coolant[motor about 5inch diam by 4inches long[no plate]] pump, from one vfd? I am guessing the coolant motor is around a 1/4hp.
Old 06-22-2009, 01:16 PM
Al_The_Man's Avatar
Do you intend to use it permanently set for 50hz?
If so, you most likely should have no problems, especially for those small a motor.
The only thing I can see is they may have to be the same pole count, 2 or 4, for setting up the parameters.
Old 06-22-2009, 02:26 PM
Seems the answer is get a vfd and see.
Old 06-22-2009, 02:41 PM
Al_The_Man's Avatar
I have used two identical motors on a VFD and variable speed/Hz, but not ones that were different size so it may be a case of each application being different and may well be a case of try and see.
Old 06-22-2009, 02:51 PM
I would be switching from the oil pump to having both pumps running.
DC motors as servo motors Doug Schwochert Servo Motors and Drives 5 12-26-2007 12:03 PM
Hot Motors Cartierusm DIY-CNC Router Table Machines 9 09-09-2007 11:27 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
What and how with these motors? Witsenburg Stepper Motors and Drives 11 04-24-2007 12:03 PM
What motors can I get from a car gv71 General Electronics Discussion 5 07-13-2004 08:32 AM
