Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 05-28-2009, 10:36 PM
reabdet21 is on a distinguished road
Acra AM-2SAC
I recently purchased the above mill with centroid controls. I thought the VFD had both single and three phase inputs but it is only three phase. I would like to update the VFD to a combinaton input and would like any information to help.
The VFD installed is a SPEECON 7200M3.
I would like to keep the remoted speed knob that is located on the machine head. Short of getting a rotary phase converter, what is my best option if I replace the VFD?
Old 05-29-2009, 07:56 PM
VFD
I called ACRA today and they suggested just hooking 230 single phase to inputs 1 and 2 leaving the third open. Obviously that would effect the output performance but I doubt if I will ever use the mill to its maximum anyway. Does anyone see a drawback to this approach? Would anyone be able to calculate the DC output voltage from the bridge rectifier in both cases? I would anticipate the single phase output would be lower but not sure how much. Thanks.
ACRA CNC plus mill any good? Jeromy General Metal Working Machines 3 03-09-2011 08:41 AM
Need Help!- Acra Milling Machine prout General Metal Working Machines 0 04-14-2008 03:11 PM
acra manual lathes jheyliger General Metal Working Machines 1 09-18-2007 11:14 PM
acra manual lathe jheyliger Machinist Feedback 0 09-18-2007 07:41 PM
Acra or Birmingham bed milling machines Chivo General Metal Working Machines 0 08-03-2006 05:42 PM
