Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 05-19-2009, 06:21 AM
George is on a distinguished road
Wrong Inverter/Spindle combination perhaps
I think I may have made a mistake.
I bought one of the Chinese 1.5kw spindle motors (Air cooled) that we see on ebay all the time. It has the following specification.
220v, 6.5A, 400Hz
My inverter drive is 1.5KW VFNC1S-2015PL-w(3)
0.5 to 200Hz, default setting: 0.5 to 80Hz, maximum frequency: 30 to 200Hz.
So the motor frequency is 400hz and the drive frequency 200hz.
Have I got it wrong?
Old 05-19-2009, 06:24 AM
TOTALLYRC is on a distinguished road
Yes.
It will only spin at half its rated speed.
Mike
Old 05-19-2009, 06:38 AM
Thanks Mike.
Is it normal then that spindle motors are 400hz ? The motor is rated at 24000rpm which means I will only get 12,000. I want to cut aluminium and wood on my flatbed router. Will that be fast enough?
I have 3 inverter drives and all are 200hz
George
Old 05-19-2009, 08:00 AM
Originally Posted by George View Post
Thanks Mike.
George
I have a drilling spindle that is 1000Hz, so 400Hz isn't all that strange.
Is it fast enough? It all depends on the size of your cutters. very small cutters like lots and lots of rpms.
Old 05-19-2009, 08:03 AM
Well, the collet chuck is Er11 so max size cutter will be 7mm
Old 05-19-2009, 09:38 AM
Hi George,
If you have an vfd already, then I would try it out and see if you are happy with the results, otherwise return it and get the correct one.
Mike
Old 05-19-2009, 10:22 AM
ger21's Avatar
Don't run it below 6000-8000 rpm or you'll burn it up. Any slower and it won't get enough cooling air.
Old 05-19-2009, 10:32 AM
Wow, thanks Gerry,
I may have to look for another VFD, that's a pity because I only just bought the 200hz 1.5Kw drive. I like the look of the Chinese spindle motors but didn't clock that they were 400hz. That's what I get for not reading the small print.
So, it's quite clear, I must match the VFD to the Spindle motor.
As a side issue these spindle motors come as 'Air cooled' or 'Water cooled' I've time to change my mind. Which is better. Water cooling sounds complicated.
George
HF spindle problem with danfoss inverter daedalus General Metal Working Machines 15 02-11-2012 11:43 AM
Fadal Spindle Inverter Troubles bart10 Fadal 5 01-12-2012 01:35 PM
Selecting a spindle inverter DanC Phase Converters and VFD 0 03-31-2008 11:40 AM
Perske Spindle & Hitachi Inverter joefish Machine Problems, Solutions , Wireless DNC, serial port 1 06-19-2007 08:36 PM
Is it possible to somehow wire this spindle inverter up to Mach3? Darc DIY-CNC Router Table Machines 6 10-31-2005 08:47 AM
