| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I know you can control them with a 0v to 10v signal, and with rotary switch's a few different ways. But what other ways can they be controlled with? Will a PWM signal work ? Or what about a Step signal from a CNC controller? I seen where modbus may be able to be used, but I don't know anything about modbus to know how this could help. Thanks Jess |
| Jess Look at Peter Homann's Digispeed boards, http://homanndesigns.com/store/index...=index&cPath=1 I use the the DC06. Uses a step signal to control rpm. Works great. Other models use PWM signal. Greg |
| Get one with relays on. DC02 or DC06. I have a DC03 and it sometimes trips when the power is interrupted to the breakout board or even with small distortion on the powerline. A little nerve wrecking when a 3hp motor starts at full power right beside your head just because you check the ingoing voltage with you voltmeter |
| MACH 3 Spindle speed input | billyfriday | Index CNC lathe | 0 | 12-31-2008 05:10 PM |
| analog input VFD speed Hitachi SJ100 | Karl_T | Phase Converters and VFD | 10 | 11-22-2008 03:09 PM |
| PC input/control with Fanuc 5 | jevs | Fanuc | 7 | 10-21-2008 09:49 PM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
| Need input for servo control systems | CNCadmin | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-31-2005 10:45 AM |
