Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 01-24-2009, 07:43 AM
jgr69ca is on a distinguished road
hooking up a phase converter with my hurco mill
Hello
I have a hurco km3p with max32 controls and I was wondering what size phase converter we will need to run the 3hp spindle motor, spindle speed motor and coolant motor all of which are 3 phase?
Also could i seperate the 3 phase and run single phase 220 to the two transformers that run all of the cnc side and just run the 3 phase motors off of a rotary phase converter?
Thanks for your help
or possibly would a static phase converter work this way in place of the rotary phase as stated above.I am just throwing this out there as a possible option.....Thanks Bob
Old 01-25-2009, 02:12 PM
sparkness is on a distinguished road
you need a 3HP VFD for the spindle rated for its max frequency read the nameplate on the motor and get a VFD that works for those parameters. a static converter will only give 2HP out of the motor. a rotary will work but no variable speed. I would use a single phase VFD and single phase for control as you mentioned. I think money spent on a vfd is a better investment than a converter just for the variable speed and braking they offer.
Need Help!- Hurco and phase converter question jgr69ca HURCO 2 01-24-2009 07:01 PM
Phase converter recommendations for CNC mill Qwikcnc General Metal Working Machines 5 12-21-2008 02:26 AM
wtb: 20 or 30 hp phase perfect phase converter gaugemate Want To Buy...Need help! 0 10-23-2008 12:06 PM
Partner 4 centurion 4 hooking up to single phase power ozturbo Milltronics 8 04-09-2008 09:42 AM
hooking computer to my hurco jpcuttergrinder General CNC (Mill and Lathe) Control Software (NC) 9 11-07-2006 10:38 AM
