| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I have an Hitachi SJ100 driving my spindle. http://www.hitachi.us/supportingdocs...ok_NB585XF.pdf I'm hooking up a 0 - 10 volt signal for VFD speed control between terminals O and L. See screen shot of manual page. OK, I set up A_01=1. Next they are talking about the AT terminal option input state and option code 16. I'm not getting what I should do. I even read the whole manual for this, still haven't got a clue. What else do I need to do? Karl P.S. screen shot not very readable, sorry. Its page 137 of 214 if you load the manual. |
| Hi Karl T Are you trying to control with computer output or just a remote control/Pot I think you may need to be looking at section 4-9 This is Forward / Reverse & Stop you will also have to set Parameters to make it work
__________________ Mactec54 |
| Hi Carl, I have the the same or very similar setup on my mill. If you don't get an answer today, I will go out to the shop tonight or tomorrow and get you all the info you need. Mine is working with the analog input, S commands and m03/m04 commands from Mach3. Way cool when it works. Make sure that you have a good digital voltmeter to verify the 0-10 volts going into the drive if we can't get it going. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| It is also advisable to assign an output for up-to-speed as the Finish signal for the M03/M04 and also zero speed is a good idea. That is if this VFD output can be configured for this. Al.
Just wait to you try to set the accel and deccel times.
| With the Mitsubishi's I use, I just perform the self tuning procedure, and then trim the decel/accel until I get an overvoltage, I have a couple of Excello mills with original 2hp motors down to around 2-3 secs acc/dec from 100hz. Al.
Al, I was contemplating programming a delay in G-code following speed changes. Obviously the signal back from the vfd is a more reliable and prescise method. But not having considered to look for this additional bit output, would you say it is fairly common, among the cheaper generics or low end Hitachi's, or do you need to step up into the big leagues for this feature? If you were to do the G-code 'pause' approach, what is the best method? Thanks in advance. |
| I have not used the Hitachi, but looking over the manual there appears to be settable outputs, There looks like two that would do the trick, code 00 IN RUN and 01 FA1 at speed. I generally look for VFD's with suitable configurable outputs, the norm in the CNC world is to have a dedicated input to the CNC controller called a FIN(ish) signal, this is an input that would go high whenever a M, S or T code is specified in the part program and has completed the task. The VFD up to speed output would trip this FIN signal. Some do not need to wait for the FIN signal, such as Coolant on/off and the FIN signal is issued immediately. I would look at the VFD output approach first before considering a pause in the program. Also the hardware solution prevents any 'accidents' due to the spindle not starting. Al.
#10
This sounds like a lot of unnecessary extra work. Why not just look at the spindle encoder? My control has a GETRPM function, maybe your favorite control doesn't do that. Now, I do think its good practice to wire all the drive fault outs to control inputs and issue a machine stop on any fault. Karl |
#11
| Al.
| Can a 3ph input VFD Hitachi J100 run on 1ph ? | maquiza | Phase Converters and VFD | 9 | 05-26-2009 10:55 AM |
| Speed controll for hitachi m12vc router? | RyanS | General Electronics Discussion | 1 | 09-29-2008 12:54 PM |
| Analog Input for Devicenet Hitachi SJ100DN2 | SirThadious | Phase Converters and VFD | 3 | 02-07-2008 03:58 PM |
| How to drive Analog Servo Input +/- 10V | gurvy | General Electronics Discussion | 1 | 05-30-2007 11:31 PM |
| connecting 4-20mA device to analog input | Karl_T | CamSoft Products | 2 | 09-02-2006 12:52 PM |
