Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-25-2008, 09:32 AM
QSIMDO is on a distinguished road
Hitachi VFD ?
I have a SJ200, 1-3 phase 3hp VFD and I can't get the motor to run in reverse.
F004 to "01" and it won't change direction.
Could someone tell me what I'm missing?
Thanks in advance.
Old 10-25-2008, 09:43 AM
TOTALLYRC is on a distinguished road
Thanks in advance.
I have the same inverter and it works great.
It depends on what you are trying to do. If you just want the motor to run the other way, just interchange 2 of the three leads going from the vfd to motor. If you are trying to turn the motor from forward to reverse and back from a remote switches, you will need too give me a lot more info.
Mike
I have mine running the spindle on my mill running mach3 and I get for/rev and Spindle spped control. It took awhile to set up but it is worth it.
Old 10-25-2008, 10:59 AM
Hi, thank you.
I'm just trying to get the motor to reverse.
Spoke with Sam at Hitachi customer service yesterday and that's all he said was "F004>func (00) >01>Run ".
The operations manual bears him out but...zip.
Still turns normal direction.
Now, all this is from the keypad. I asked him if I need a remote input and he said no.
I could wire in a switch to swap motor leads but I reckon the VFD should do this and high-five me when it's done!
Old 10-25-2008, 11:50 AM
Hi, thank you.
If I understand you correctly, all you want to do is a one time reversal to make the motor go the other way. All yo have to do is swap any 2 of the three wires going to the motor. It will take all of 5 minutes and can be done right at the drive.
Mike.
I agree that all you should have to do is to change the setting but it is what it is.
Old 10-25-2008, 12:04 PM
MrWild is on a distinguished road
No, sounds like he has a High/Low gear change and needs to be able to run the motor in reverse for the gear change.
Old 10-25-2008, 12:17 PM
On mine, which I am pretty sure is the same as his, you do not have the option for forward and reverse from the keypad. If he needs to forward and reverse on a regular basis, he needs to set up a couple of switches.
Old 10-25-2008, 02:08 PM
Not from the keypad then.
Ok.
How about this?
http://www.driveswarehouse.com/docum...chi/SJ200M.pdf
Mind, this entire document could be in Sanskrit for what I'm comprehending but, section 4-12 shows a simple switching affair between logic inputs 1, 6 and PCS....?
No? Yes? Or just swap the bleedin' ouput wires as the gentleman suggested?
Old 10-25-2008, 07:38 PM
mactec54 is on a distinguished road
Hi QSIMDO
I think you ment Logic 1 & 2 will get you the forward/reverse you are looking for you will have to set some parameters as well
This is the only place you can switch to control your drive apart from having a remote
Do not try to put a switch between any power or motor wires
If the drive did no change direction when you changed the parameter you did not do it correctly
Mactec54
Old 10-26-2008, 02:06 AM
Ok.
How about this?
Hey Quismodo. I took basic sanskrit in high school
Please answer the question. Is it a one time reverse or is it something that needs to be done all the time?
I will help you either way but you are not being clear.
Mike
Old 10-26-2008, 08:52 AM
Frankly, it's not a huge necessity but merely based on the fact that I inherited a WHOLE bunch of left-hand end mills!
Thought if I could just poke a button I'd burn 'em up but, if not, I can always grind profile tools for the lathe!
Ta!
  #11   Ban this user!
Old 10-26-2008, 09:25 AM
Ta!
It is pretty easy to set up a switche to make it go forward and reverse. The drive supplies the common and you go to term 1 and 2. All you do then is make sure you set up your intelligent terminals to for andd rev.
Mike
  #12   Ban this user!
Old 10-26-2008, 03:38 PM
"The drive supplies the common and you go to term 1 and 2. All you do then is make sure you set up your intelligent terminals to for andd rev.
Mike"
Ok Mike.
I'm certain my wife will back me up on this when I say I'm an idiot with this stuff and haven't much of a clue what you're talking about.
You got a schematic for all that?
Crayon, chalk...I don't care.
Oops, wait a minute...I just looked at the manual. It shows coming from "PCS" to switches on "1" and "2", 1 being Forward and 2 being Reverse.
Is that it?
Don't wish to fry anything.
Need Help!- Hitachi Seiki wiks General Metalwork Discussion 0 10-11-2008 01:20 PM
Need some help with Hitachi L100 rustamd Phase Converters and VFD 22 10-20-2007 11:07 AM
Hitachi 6M Spinner Plasma, EDM and other similar machine Project Log 0 07-06-2007 01:21 PM
Hitachi Seiki mroy0404 Mazak, Mitsubishi, Mazatrol 0 05-07-2007 11:28 PM
Hitachi router rustamd DIY-CNC Router Table Machines 3 04-14-2007 10:47 AM
