Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 08-11-2008, 06:18 AM
Supercel is on a distinguished road
ENCO 13 x 40 lathe and VFD
Hello-
First time poster here.
Just got an ENCO geared head (308-0233) lathe, and plan to install a VFD to run spindle--no problem with that. A minor issue is the coolant pump, which runs a small 3 phase motor. I have two choices--either replace this pump with a single phase unit, or get a real cheap single to 3 phase converter to do it. Isn't there a simple capacitor only conversion out there for this? If so, is there a reference on-line that could assist with this?
Thanks!
Tim
Old 08-11-2008, 08:41 AM
Al_The_Man's Avatar
If this is a 220v motor, usually fractional VFD's are cheap on ebay, otherwise you could experiment with setting it up like you would an RPC, there are quite a few links here on building tuning etc, this would involve a push button start and some run caps.
Probably frequent start stops might make this method impractical.
Wanted Enco Lathe Model 110-0818 SWITCH chrysler48 General Metal Working Machines 1 08-31-2011 04:02 PM
Wanted Enco Lathe 92030 owners manual A-1autouph Want To Buy...Need help! 0 05-01-2008 05:20 PM
Enco 14 x 14 lathe? dannirr General Metal Working Machines 0 04-21-2008 09:02 AM
Need Help!- Enco 9 x 20 Lathe Restoration warossignol Mini Lathe 0 04-03-2008 02:40 PM
Enco Lathe ccm Mini Lathe 3 10-21-2003 04:34 PM
