| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Hey guys, so I been lurking here for some time reading and what not. I recently landed a new free Baldor Standard E 3 ph motor to use with my grizzly mill ( on order now ). Also just bought a 2HP single phase input 3 phase output VFD for a good price made by Bedford. Any way, I been tinkering with it and testing it out, lots of options but one really confuses me. Setup ( Motor = 4 pole 1740RPM 60hz 230V FLA = 5.6 amps 84% efficient ) Bedford VFD 2HP ( mostly original setup as manual, Other then sine wave carrier is at 15KHz - I don't think that effects any thing other then that annoying pitch I hear at slow speeds. Ok so I start her up and run it to the RPm range of about 1500RPM or so......Grab the shaft with glove and clamp down, I can literally stop the motor, then it doesn't want to come back up to speed, Is this motor not capable of being fed by a VFD? I have the VFD setting on constant torque, but I am wondering what is going on exactly.......I know know much about VFD's so if some one takes a peek through the PDF and suggests some settings I am all yours! I bought 2 VFD's to go onto my lathe and mill, basically both motors are identical, other then the FLA, one is 5.6 the other is 6, So I would really like this working. Mind you I wont be turning the Hz down so far for the torque to be non existent, since the mill and lathe both have belt or gear adjustments - So if I want to run fast Ill put then mill or lathe down into the basement for RPM on the machine, then fine tune with the VFD........Right? Thanks every one! Last edited by ger21; 10-01-2011 at 06:01 PM. |
| Was there any code on the display? I would think if you went into current limit, it should have given a fault code. Al.
| No the motor was free ( it was surplus we didnt need, still wrapped in the baldor box and shrink rap. Umm there is an option for F-11 motor pole pairs, its default is 2, Does it mean 2 pairs of 2 or just pairs? In that case I should set it to 4 no? since its 4 poles........ Also how does this DC injection thingy work? Also what is this slip compensation and how do I work it? LOL I am such a newbie! Thanks guys |
| bahhh problem solved.........I connected the wires to the motor side not the the line side. She turns with SERIOUS troque now! OK technical questions Slip compensation DC injection start and stop voltage boost ( % max output voltage ) Carrier wave selection ( KHz) And any thing else the PDF might have for me thats useful, Thanks! |
| Do you have the manual with the VFD? it should tell you how to hook up the 1 phase in, usually on the R & S terminals if it has R,S,T. You mentioned already it is a 1 ph input. The 3 phases to the motor are usually labeled U,V&W. These 3 conductors should be twisted together and wired with no interruption directly to the motor, a suitable ground conductor should go from the service ground to the VFD and then to the motor frame. A 15amp breaker should be ample. The rest is parameter setup and I/O wiring, which depends on how you intend controlling it, i.e. manually or by CNC input etc. This you would have to refer to the manual. Also, if the unit is capable of self tuning to the motor, this should be done also, for maximum performance. Al.
#10
| Hey Al, Thanks a bunch for the reply! Ok I am fallowing your information to the T, I got the basic idea I just wanted to confirm thats all.........My user manual does show ground, but there is no dedicated pin or screw terminal for it, these damn chinese! http://members.shaw.ca/H2O2/images/B...r%20manual.pdf is the manual. Any way I will twist the VFD to motor wires together and run a ground from my sub panel to my VFD then to my motor, if I can figure out where to wire my ground wire?! Also checking the name plate and VFD specs, nothing should really exceed 7 amps, Would a 10 amp breaker suffice, I have 1 kicking around and thought I could save some $ by using the 10 amp, what do you think?! Thanks Al |
#11
| That link did not work, It is odd that the VFD does not have a ground terminal. You can use the 10amp breaker, with a VFD the normal motor inrush is eliminated so it should work out, if you get nuisance tripping, you can always up it later. Al.
| Need Help!- problem with Baldor inverter | dango | Fadal | 3 | 06-27-2008 11:47 AM |
| Baldor drives | nicolae | Fadal | 0 | 03-10-2008 05:27 AM |
| Baldor Servos And Drive | Cycle Start | Servo Motors and Drives | 0 | 05-29-2007 07:28 AM |
| Baldor sweodrive | AndyB | Fadal | 2 | 12-08-2006 09:16 AM |
| Baldor SMCC help needed | foamcutter | General CAM Discussion | 9 | 07-05-2004 08:11 PM |
