Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 07-30-2008, 01:20 PM
zook is on a distinguished road
Hurco SM1 CNC with VFD anyone?
Hey:
I have an '84 hurco SM1 CNC mill with the pnuematic manual spindal speed control. I would like to put a VFD on it. It is 3hp
Is anyone out there running this setup?
It has high and low gear as well as a dial adjustable pnuematic speed control.
Where do i start?
Thank you.
Patrick
Old 07-30-2008, 03:49 PM
Al_The_Man's Avatar
If it is any thing like the manual VariSpeed system, I have removed this and fitted a 1:1 motor to gearbox with timing belt arrangement, the 2 speed gearbox is an asset.
You may want to get a 5hp VFD to allow some derating for 1 phase.
Check the motor to see if it is 4 pole, 1745 rpm?
Generally you can run these motors at 2x the base speed by using up to 120Hz output from the VFD.
Old 07-30-2008, 07:13 PM
Thanks.
When you say derating, do you mean that it won't produce it's full 3hp?
Can anyone out there recomend a 5hp vfd that is one phase in 3 phase out? The only one I have found so far is $600 compared to about $250 for the 3hp models i've been looking at.
Pat
Old 07-30-2008, 09:27 PM
I just checked, it's a 4 wire 1800rpm motor.
Hurco BMC-30 w/ATC jpetrie HURCO 4 01-06-2010 11:52 AM
Problem- HURCO BMC 40 drewcuzz594 HURCO 4 05-05-2008 10:37 AM
Hurco VM1 Steve@Reliance HURCO 5 03-05-2007 03:32 PM
Hurco GRANDPA Suggestions for the CNCzone.com site. 1 02-20-2007 08:36 AM
Hurco 78 stingray Post Processor Files 0 02-03-2007 06:03 PM
