Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 07-21-2008, 04:48 AM
hamholfarm is on a distinguished road
High Pitched Whine From VFD Driven Motor
Hello,
I have attached a Hitachi SJ200-022NFU2, 3 HP - VFD to the 2HP, 3-phase motor on my Sheldon Lathe. I followed the instruction booklet for the wiring, then performed the “Power-Up Test” with the correct results. Then I configured the initial run parameters per the instructions.
When I turn the potentiometer up, just before the motor starts to spin, I get a very high pitched whining noise. As I continue increasing the pot, and the motor increases in speed, the whining lessons a little bit, but it remains. The sound is definitely coming from the motor and not the lathe itself. Any ideas of what could be causing this? The only thing I was not positive about setting up the VFD was the number of poles on the motor. I entered 4, which was the default value. The motor has 9 wires coming out of it and they are grouped as follows: (4+5+6), (1+7+L1), (2+8+L2), (3+9+L3), is this correct? If this is correct, what could be causing the whining, and how would I fix it?
I thank you in advance for the help.
Chip
Old 07-21-2008, 07:47 AM
Al_The_Man's Avatar
On some VFD's you can change the switching frequency which may cure it, you may also have loose laminations or.. in the motor.
The pole count can be obtained from the motor nameplate rpm.
A 60hz 2 pole motor will run ~3500rpm, a 4 pole ~1700 range.
Old 07-22-2008, 03:04 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question High pitched whine.
Good to hear you got it working.
The whining is the VFD CHOPPING the supply to the motor which is the way it makes the 3 phase power. Some questions...
1). What have you set the current limit setting to?
2). Can you measure the input mains with a tong tester?
3). What is the motor plate ratings.
4). Does the motor plate have details of the wires as you describe them?
It is probably a dual voltage motor. If that is how the wiring was don't change it unless you have a reason.
5). Was it originally run on 220v 3 phase?
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 07-22-2008, 05:55 PM
Willbird is on a distinguished road
The motor on a Bport I just installed a VFD on was making a whining noise, I changed the carrier frequency from 6kHz to 4kHz and the slight whine is only present on acel or decel now.
My drive is an AC Tech.
Bill
Hearing saftey- stepper motor PWM whine nullbert Benchtop Machines 1 07-04-2008 08:43 PM
High Torque , High Bandwidth Motor or Servo mastabib Benchtop Machines 0 09-26-2007 02:09 AM
Motor whine, no rotation flyboy1015 Mach Software (ArtSoft software) 9 03-02-2007 09:32 PM
Whine / squeal noises when machine idle bkraz Bridgeport and Hardinge Mills 5 02-09-2006 05:29 AM
