Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 06-06-2008, 08:58 PM
Stepper Monkey is on a distinguished road
determining phase sequence
This is my first foray into wiring anything 3-phase myself, so I have a really stupid question;
I am trying to hook a VFD up to an unbranded HF spindle (very similar to the one sold by Homeshopcnc). It came with no diagrams or provenance to obtain them. It has a connector with 4 leads, meaning the motor is configured internally already. External markings are limited to: RH62DX-.08/11, 400hz, 24000rpm, 220v, 3.9a
My problem, given access to just those leads, how do I determine proper phase sequence to hook them up?
Old 06-06-2008, 09:13 PM
Al_The_Man's Avatar
By looking at the one on the HSCNC site, I would think that three are the 3 phase in and the fourth possibly a ground.
You could confirm this by taking a reading from the case to each pin in turn.
If so, you hook up the VFD to the remaining three and swap any two of the three leads to reverse.
Old 06-07-2008, 06:25 AM
Yes, it does appear that they are for the three phase in with one ground. My only worry was that if the order of the phases in could not be arbitrary (i.e. only one correct order to hook up for each direction), that I could screw something up. Dumb question I know, its my first time with 3-phase.
If order does not matter, and I can safely hook up the the three inputs in any given order without fear of damage, and to switch any two for rotation, that answers my question. Thanks!
Old 06-07-2008, 06:55 AM
epineh is on a distinguished road
Yup you have it, connect it up and swap any two if it goes the wrong way. Make sure you identify the ground properly and it should be fine. Also most VFD's I have installed will allow you to reverse direction either with a parameter or button on the panel, but swapping two phase wires will work as well.
Russell.
BOSS 8 EMC boot sequence jonny Bridgeport and Hardinge Mills 2 04-02-2007 09:00 PM
cut sequence camtd Surfcam 2 06-13-2006 11:26 AM
Sequence #'s Mountainwildman Post Processors for MC 2 04-02-2006 11:25 AM
Wire sequence? scratch_6057 Stepper Motors and Drives 3 03-30-2006 07:33 AM
Power up sequence Konstantin General Electronics Discussion 1 10-05-2004 05:05 PM
