Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 05-08-2008, 07:47 PM
ideffects is on a distinguished road
3 Phase Converter Wiring
Hello,
I just found this forum and I hope you guys can help me with a wiring question.
I have a 3 phase converter and I need a little bit help wiring it to my specific receptacle. I have wired a converter to a piece of machinery before but this one is a bit more difficult and I don't want to screw it up.
The outlet I have to wire is a NEMA L21-30. It's a 5 wire outlet. My 3 phase generator consists of black, red and blue (plus ground - no common). I know I can use the pre-existing ground but how about the common from the single phase (I think I can)?
Below is an image of the receptacle.
How I would wire it would be
X - Black (L1)
Y - Red (L2)
Z - Blue (L3)
W - Common
G - Ground (Existing Ground From Single Phase Power)
Would this be correct?
Thanks in advance for the help!
Old 05-08-2008, 07:53 PM
Al_The_Man's Avatar
If you intend using W as the neutral, it should not be grounded as shown, although it is connected to ground in the panel.
Also, the neutral can only be referenced (used) with respect to the two original 240v 1 phase conductors.
Old 05-08-2008, 08:01 PM
Thanks for the quick reply. I think I understand what you are saying but I just want to clarify. I will be using the common (W) from the original 240 and that goes to the breaker panel. That's what you mean, right? Also how about X Y and Z? Does that look right?
Old 05-08-2008, 08:09 PM
Al_The_Man's Avatar
Yes, I assume that Y is the artificial phase?
Old 05-09-2008, 04:36 PM
Thanks for the help Al!
I am not sure if Y is the artificial phase. How can I verify that? Also, I made a diagram to show what I want to do.
Old 05-09-2008, 04:44 PM
Al_The_Man's Avatar
The two conductors marked HOT go straight through to the receptacle.
How come you need a neutral that way anyway?
If you have any other equipment that uses the neutral. it should be on a circuit of its own, not off the RPC output.
Normally for typical RPC loads you do not require a neutral.
Is the convertor static or rotary?
Old 05-09-2008, 05:34 PM
The converter is a 10HP CNC Rotary and the only reason I am concerned about the common is because that's what the specs say.
Old 05-09-2008, 06:59 PM
Al_The_Man's Avatar
I have never seen a RPC that needed or supplied a neutral, unless it was used internally for contactor switching etc.
DIY 3 phase converter blackbeard52 Phase Converters and VFD 2 01-16-2008 09:46 PM
phase converter rob jerico Fadal 13 09-02-2007 12:32 AM
phase converter contractdesign Bridgeport and Hardinge Mills 8 05-30-2007 03:39 PM
RF from phase converter ? DieGuy Phase Converters and VFD 1 10-20-2005 07:14 AM
Phase Converter Wiring freak_brain General Electronics Discussion 2 03-15-2005 12:56 PM
