| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I would like to buy this lathe http://tinyurl.com/34ufcb This is the motor info Type 2 speed induction HP 3-4 Voltage 220 Prewired 220 amps 17/8.5 speed 1750/875 cycles 60 number of speeds 2 I would like to use this VFD with it and I will be putting 220 single phase power IN. http://www.wolfautomation.com/Produc...roductID=18805 I am wondering if it will be reasonably simple to wire the vfd so the original lathe controls will turn the spindle on and off and reverse the spindle...I assume the machine will have contactors in the control box that would control the motor on 3 phase, and I could rewire things so the contactors controlled the vfd. On the 2 speed motor deal I'm wondering if that can be made to work with the VFD or not ?? The slower speeds are needed to thread...BUT if I could just run the motor at 50% of full speed then it would do the same thing as running it at the lower speed. Thanks for any help yaal could offer :-) Bill |
| http://www.cnczone.com/forums/showthread.php?t=25061 This thread answers part of my question
| Isn't that a gear head lath? If so, why not use the high motor speed and use highest gear and one gear for low speed, this enables you to maintain a high motor speed for low chuck speed. Al.
| Yes it is a gear head lathe, however it's lowest speed is 45 rpm, this would be with the motor running 875 rpm. The lowest speed with the motor running 1750 would be 90 rpm, which might be too fast for a coarse thread (cutting speed would be ok but you would have very little time to pull the half nuts out if you were threading to a shoulder) This looks to be how the speeds work out......... motor hi speed motor low speed 1800 900 1170 585 770 385 510 255 330 165 215 108 140 70 90 45 |
| http://www.grizzly.com/images/manuals/g0509g_m.pdf Page 54 has a picture of the control cabinet inside I see the coolant pump is a 1/8 hp 3450 rpm 3 phase motor too.......another 190 bucks for a vfd to run the coolant pump grrrrrrr hehe. Bill |
| New Grizzly G0602 10x20 Lathe | twehr | General Metal Working Machines | 159 | 04-17-2012 06:50 AM |
| CNC bigger Grizzly lathe - anybody? | Spinnetti | Mini Lathe | 6 | 02-06-2008 05:41 AM |
| Any opinions on the Grizzly g4016 lathe or other Grizzly lathes? | DublD | General Metal Working Machines | 3 | 11-26-2006 12:23 PM |
| Buying my first lathe, Jet, Grizzly, Central, Prazi | Noah | General Metal Working Machines | 9 | 09-05-2004 10:35 AM |
| New Grizzly Lathe what else do I need? | CNC Brute | General Metal Working Machines | 6 | 03-03-2004 06:03 PM |
