Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 01-22-2008, 02:22 PM
toby51 is on a distinguished road
No Power Help
Hi,I have a desktop router, i was engraving,when the spindle stopped.I reset the machine it started for a few mins,then cut out again with E.009 on the LED display.
Now it will not power up at all,but when the run button is pressed a small light shows it is running,but nothing.
On the inverter it has 100H-1.5K.
Could the trouble be in that.
Mike
Old 02-05-2008, 10:58 PM
pike88 is on a distinguished road
Mike, Check if the ground wire came loose.
power up tonykat Controller Cards 3 01-03-2008 04:48 PM
Power one Power Supply teamtexas General Electronics Discussion 3 10-13-2007 05:05 PM
power for fan dpilott General Electronics Discussion 3 07-24-2007 10:34 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
