| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Basically I am looking for something that can change 60hz to 50hz for power. I do things with compressors and my market is reaching into out of US market... and was wondering if there are some recommendation for such device. I will be looking at about 2 hp usage. Thanks in advance |
| I imagine you need this for testing? As if you are shipping to a 50Hz destination you would not need the conversion shipped with the unit? If so, the quick solution might be to look at an ordinary VFD the output can be set to desired Hz, but the output is 3 phase (1 phase or 3 ph input ). I am not sure how it would take to 1ph loads, if this is what you have, unless you put two loads on at once. Also the output is 240vac, which most 50Hz destinations are. If testing compressors, you might want to go with a higher HP rating. You can usually pick up deals on ebay. Al.
| Where do I put this thing? | Sal@TKL | General Metalwork Discussion | 2 | 04-17-2007 10:25 AM |
| First thing done on my router | wedge | CNC Wood Router Project Log | 10 | 10-14-2005 08:36 PM |
| what is this thing for? | bigal | General Electronics Discussion | 35 | 07-08-2005 07:05 AM |
| What's this thing for? | Chunky | General Metal Working Machines | 11 | 07-02-2005 01:34 AM |
| What is this thing? And what 'exactly' does it do? | DAB_Design | Benchtop Machines | 7 | 09-17-2004 03:42 PM |
