The cost depends a lot on the horsepower of your machine. Ebay has lots of phase converters for sale. You need a realistic approximation of the true power draw of the machine including spindle, coolant pumps, and hydraulic pumps. So you might have a 5hp spindle but there's a 1hp coolant pump in the base and a hydraulic pump that uses 1hp. If you go too small on the converter, whenever you turn the coolant pump on, you can trip a circuit breaker.
Generally, the rotary phase converters are better than the static phase converts. Obviously, the rotary converters are also more expensive. Both my VMCs are running on rotary converters.
LinkBack URL
About LinkBacks
