Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 05-18-2007, 11:54 AM
gearsoup is on a distinguished road
Converting a Roto-Phase for use with a CNC....
So, I am looking at purchasing a couple CNC's for my shop. One is a SuperMax Max-1 Rebel VMC, 7.5 HP spindle, and the other is a SuperMax TC-2 lathe, with a 10HP spindle. I live out in the sticks, so 3ph power is about 4 miles away.
I currently have a Johnford SV-40, 15hp spindle. I am running that off of a Phase-A-Matic that I got from MSC (IIRC). I've had zero problems with it.
Someone locally is selling two 15hp Roto-Phase (that's the brand) converters.($900 each) They do not have any voltage regulating stuff on them. I called up Arco (the mfg.) and they said they were good for around 7% variation. I asked if it was possible to install a voltage regulator along the line, and power a CNC. They said absolutely not!
Now, I'm not an electrician by any means. I took me a LONG time to wire up 3 geckos to power my CNC router I built 5 years ago. Not much has changed for me since then.
However.....
Common sense tellls me that they are just trying to get me to buy a new unit...
What say you?
My Phase-A-Matic has a seperate voltage regulator. This can be purchased seperately from the actual converter. Any reason why I can't use that on the Arco? A local distributor can get the regulators for aroung $800 for the 15hp model.....
Old 05-18-2007, 01:05 PM
Al_The_Man's Avatar
Really need to know what technology the regulator is, Active (electronic), Passive etc. And where in the line it is installed.
Old 05-19-2007, 07:48 AM
Well, like I said, I'm no electrician. Hope these pictures explain everything....
Old 05-19-2007, 09:34 AM
Al_The_Man's Avatar
Looks as though it is a simple choke or inductance connected from the artificial phase to one of the main feeds, I cannot see it being a problem as to what kind of convertor you use.
With a RPC, they are usually optimally tuned for best power factor (efficiency), this may be being used for this purpose.
There are alot of RPC's running CNC equipment.
Old 05-19-2007, 10:58 AM
Now, that is my current setup.
What I want to do is get 2 more that don't come with voltage regulators, get identical regulators like the one I already have, and presto, CNC rated RPC's...
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Converting to Single Phase 4020 fadal chipsahoy Fadal 6 03-02-2006 10:27 PM
3 phase transformer - on single phase? zcases General Electronics Discussion 3 10-21-2005 10:22 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 11:25 AM
2 phase vs 4 phase stepper motors Don C General Electronics Discussion 1 05-26-2004 01:40 PM
