Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 04-20-2007, 10:42 PM
bcromwell is on a distinguished road
Suggest a VFD
Looking for a VFD based on my motor and have a couple questions..
The Motor is a GE TriClad with the following on the plate:
Base Rpm 1745, 2 HP, 240 Volt 3 phase
90 Herz 4.6 amp, 1.7 hp, 2620 rpm, 240v
26 Herz 7.7 amp, 2 hp, 745 rpm, 200v
Type KAF Induction Motor
So I guess I can assume this is a VFD rated motor, is the 90 hz the recommended max hz? Can I run at 120hz intermittently (This would give me about 3500 rpm if my math is correct)
Will most any 2hp VFD work with this motor? Any suggestions?
Old 04-20-2007, 11:11 PM
petek is on a distinguished road
you should use a drive that can be set up in v/h mode so you can set up a custom curve to match the name plate ratings. fortunatly you can ussually find that these are the least expensive of the ac drives. check automation direct should be able to find new for about 200.00
Pete
Pls suggest a mill fit cutting Stainless steel szcharle General Metal Working Machines 0 07-12-2006 10:22 PM
Suggest a breakout board plz cncuser1 Xylotex 7 05-02-2006 07:57 PM
Suggest some software! Please disinformation General CNC (Mill and Lathe) Control Software (NC) 2 01-13-2006 04:16 AM
Someone suggest a machine!! leewinn General Metal Working Machines 0 11-21-2005 11:53 PM
Can any suggest CNCadmin CNC Wire Foam Cutter Machines 4 04-06-2004 11:23 PM
