Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 04-11-2007, 09:58 AM
xjack is on a distinguished road
IR2130 Not working
I wired ir2130 as DT 94-11 Design Tips
The Problem is when i start the Motor it Runs normal 2 to 3 time
then if i start the motor it strugles to run or runs steped
after changing new IR2130 it runs for one time and again it strugles to run ?
http://www.irf.com/technical-info/designtp/dt94-11.pdf
Working with MDF Miguelflores General Material Machining Solutions 9 03-16-2008 05:45 AM
Eia Iso Not Working honk Mazak, Mitsubishi, Mazatrol 12 08-16-2006 08:17 AM
She was working utengineer04 Bridgeport and Hardinge Mills 1 07-25-2005 10:39 PM
What I'm working on- CNCadmin Forum Questions or Problems 2 07-22-2004 12:31 AM
Something I was working on when 22 Hobbiest CNCzone Club House 1 03-13-2004 08:27 AM
