| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
#13
| PF is power factor. Don't know why there is no nameplate amp rating. 8.0amps seems on the high side, because my 3hp baldor motor is rated for 8.2 amps at 230volts. The parameter setup for milling machine are nice to know. |
#14
Since you answered you own question I don't need too. chris |
#15
| chris |
#16
| I finally got everything hooked up, adjusted and ready to run. The pulley selection I fitted provides 2,500 RPM at the spindle when the motor is turning 3550, the full 60 cycle speed. So I have been experimenting with this arrangement and the results are very positive. I put a 3/4" endmill in the collet and took some cuts on a big bar of mild steel at 10 cycles. The cuts were fine and the machine performed without protest, plenty of power. It seems that the goal of no belt changes and sufficient power for all operations, low to high speed, has been achieved. On a side note, I eliminated all of the additional pulleys and belts, I run just two pulleys and one belt instead of the previous set up of four pulleys and three belts. The difference in smoothness is exceptional. |
#19
| so 10 cycles nets you around 410 rpm at the spindle. so you are using the constant torque setting instead of sensorless control. good to see that it worked out for you.
#20
| This application being a bit different from the likes of a Mill etc, I would think it is probabally critical that you do not exceed the F.L.A. of the motor, If you can get hold of a Clamp on ampmeter you could see what the Maximum present current is at 60hz, this will be with both intake and exhaust as unrestricted as possible, Then take it up gradually to 120hz and see what the effect on current is. I would think the tendency for the current to climb will be offset by the increase in impedance. Any restriction of the intake or exhaust after this should decrease the current proportionately, presuming it is a centrifugal impeller. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 04-10-2007 at 03:32 PM. Reason: wrong term |
#22
| If your drive has the setting, turn it to constant HP, since this load is dynamic, they may word it in different ways, vectoring will be of little use to you in that application. As far as "juice" goes, your drive won't really let it get more then it can handle if its set properly, you can fudge the settings but its been my general experience that you can't really fudge the numbers to far outside of what the nameplate states. The motor itself is the biggest limit as to what it will draw, as long as the line voltage is steady(most drives don't increase over rating or input) its only going to draw so many amps regardless of what you try and do with the drive although the drive might let you over volt the motor some. As for over 60 Hz threshold your amps will go up to the roof, it may not be possible to get that motor to 120 Hz, the torque will increase ever rpm faster that motor spins(assuming its a centrifugal blower). When I said what class is the motor your response was with the insulation class of F which is good for your use, but there is also a motor class, in your case I think its C but I am only goin on what you have provided. This would make this motor a compressor duty motor, they respond well to a mild to heavy torque at FLA but don't like over or under speed as much(they are designed to have higher torque so the amps go up), which means this motor will more then likely not like the increase in Hz and result in higher then required amp draw in those areas. If you are doing the Bill Pentz design you may need to switch to a 2 pole motor even at half and 3/4 speed that will not draw anywhere what you need for CFM. I think the clear vue guys are running 5HP 2 pole lesson motors, I could be wrong though. 182 frames like to be torquey motors, your amps indicate also that this motor would be better suited for such, you HP will not go above 3 it flat lines at the 60 Hz threshold torque will only reduce from that point esp bad in dynamic loads. If I were to take a jab at 3 HP you might make it to 75 HZ before preforamce degrades since its 1.15 SF motor. chris |
#24
| Yeah then I would go with the 2 pole motor, 3 HP nema class B or C would be best(I think 4 is min really for multiple inlets) anything less you will not get the needed static pressure and a suitable vortex, they have tons of info on the clear vue and pentz sites I suggest you read it all, one day off in the future when I get rich (quickly) I hope to build one so let us know. I am hoping to buy the clear vue mini (cv-o6) for a router table I am building after I get done with my mill. chris |
| Problems with motor stalling due to motor/lead screw alignment | Bimmerkc1 | DIY-CNC Router Table Machines | 3 | 01-24-2010 06:12 PM |
| Advice about stepper motor | rbb_UK | Stepper Motors and Drives | 1 | 01-18-2007 12:18 PM |
| Newbie looking for stepping motor and driver advice | maquiza | Stepper Motors and Drives | 1 | 09-06-2006 06:08 PM |
| Planning a mill, need spindle motor advice | MrRage | General Metal Working Machines | 0 | 09-26-2005 03:38 PM |
| Router Motor Advice Please | Moondog | DIY-CNC Router Table Machines | 2 | 11-03-2004 01:49 PM |
