| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
http://www.grizzly.com/catalog/2007/Main/534 they refer the potential buyer to a 15 horsepower rotary phase converter that grizzly sells for $1750 ?? sheesh, that is a deal breaker. Can I use a VFD with a two speed motor ?? Bill |
| Look for a quality unit (VFD) on ebay, you can get 5hp or preferably 7.5hp that will operate on 1 ph input. You can operate the motor on a VFD wired for one speed. If you pick up a 5hp VFD, the lower speed rating might be the best way to go the with the VFD set for top limit of 120hz. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Honestly Al I'm not afraid to buy a NEW VFD for this app. Even that would be far cheaper than the rotary phase converter Grizzly specced for this lathe. Wiring the VFD might be a bit scary for me :-)...I THINK these machines use the "on" lever to actually turn the motor on IE the motor does not run all the time with a mechanical forward and reverse clutch but rather the spindle lever turns the motor on in either forward or reverse. If it follows the format of the small jet lathe we have at work there is a two position switch to set the motor to high or low speed. There is some potential that I may cnc this lathe after I get it. Bill |
| Converting my Engine Lathe to an 8-Station Turret Lathe! | widgitmaster | General Metal Working Machines | 93 | 10-31-2011 04:27 AM |
| CNC "KIT" for 8x12 8x14 mini lathe - or cheap/small CNC lathe? | tinkering | Mini Lathe | 15 | 05-05-2011 06:59 PM |
| Lathe Comparison - Best small lathe for CNC | acondit | Mini Lathe | 48 | 03-23-2006 08:10 PM |
| Anyone have a mini cnc lathe or medium sized cnc lathe | nymachinist | Mini Lathe | 6 | 01-23-2006 09:36 PM |
| New Micro lathe built by me (my second lathe) | Stevie | General Metal Working Machines | 15 | 11-03-2004 04:56 AM |
