Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 02-21-2007, 12:22 AM
Helix60 is on a distinguished road
VFD = Balancer?????
OK heres my question as a story problem.
I currently have a 3 phase rotary converter in my shop. 10HP works great for general machining, and the two CNCs I have both VMC's. Of course I did have to make sure L1 L2 were wirred to control phase of transformer. I'm getting a wire EDM machine this Friday and as far as i can tell there is a +/- 5% voltage rating between phases as a requirement. What I would like to know is if I can use a VFD after the rotary to help balance the phase voltages to supply the new EDM?
Also what does the AMP rating on a VFD mean AMP/Line or total AMP draw? Is a VFD more efficient when supplied with 3 phase than single?
Regards,
Heli
