Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 02-10-2007, 04:21 PM
Napier is on a distinguished road
Which Vfd for my sander?
http://http://www.grizzly.com/produc...440|550|500000
Im about to purchase this sander/grinder and I need to convert it to singlephase I was just wondering If you guys reccomend a vfd or a static phase convertor. Im new to vfd's and dont have any expeirence with them I have basic electrical skills. Im just not sure what would be best. Any help is appreciated thanks
Old 02-10-2007, 05:02 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Hey - I just saw you over on the Hobart forum.
Welcome!
I will be back with a few links for your searching pleasure.......
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 02-10-2007, 05:10 PM
Al_The_Man's Avatar
Not sure what you are trying to do? If the one you want only comes in 3 phase then you have a couple of choices, either a phase convertor from 1 phase to 3ph, or a VFD, usually you do not require speed control on a grinder, but with a VFD you would have the choice.
If you want to convert a 3 phase motor to 1 ph you will need to change the motor, as these 1ph motors are split phase, and you cannot run a VFD on them.
Old 02-10-2007, 05:15 PM
I just wanna get it running of 1 phase power since thats all i have. I just wanna do whatever is cheaper either vfd or phase convertor. i havent found a vfd's for 4hp motors that will work from single phase power on 3 phase motors
DIY 26"+ sander greenail WoodWorking 13 05-09-2007 09:30 AM
Suggestions for industrial Belt/Disc sander mxtras General Metal Working Machines 6 01-28-2007 02:35 PM
Disc Sander? Zumba General Metalwork Discussion 3 04-05-2006 10:33 PM
Home made drum sander CNCRob WoodWorking 43 01-01-2006 11:29 PM
Drum Sander Plans Available Hack Product Announcements & Manufacturer News 0 09-17-2005 04:19 PM
