Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
  #25   Ban this user!
Old 03-22-2007, 02:36 PM
bilinghm is on a distinguished road
I examined my VFD and I see the jumper to which you refer. It is a small sheet metal bridge that permanently connects the first two terminals on the left on the second row. It was my understanding that the second row of terminals were not a part of the power wiring diagram, but are associated only with braking functions.
There was some discussion of creating a wire jumper to connect L1 and L2. I now see that the "jumper" that appears on the confusing and inadequate wiring diagram from Hitachi is actually the factory installed treminal bridge you have pointed out. Mystery solved! Thanks!
Originally Posted by wildcat View Post
There is a jumper on the second row of connectors on the left most side of the group of three (pins named +1 and +). Looking at page 2-20 of the SJ200's manual you will see this jumper connecting the pins in black (versus the pins in white where you make your power connections. Just don't confuse these pins as with the bottom most row. The diagram is a little confusing really... they tried to pack too much on the page. You can also see the jumper in the photo on page 2-22. For me this jump was installed when the 3HP SJ200 arrived. It's probably on yours already as well.
  #26   Ban this user!
Old 03-26-2007, 09:51 AM
PaulCurtis is on a distinguished road
SJ200 Issue
The three phase inputs of the SJ200 are totally symmetrical, so technically, single phase can be connected to any pair of terminals. The reason jumpering to the "unused" phase is required in some inverters is to because they have loss of phase detection. Adding the jumper fools the drive into thinking there are 3 phases present.
As for the drive that had power wired to the second terminal row, it is probably damaged beyond economical repair, unfortunately. We have noted that the single-phase wiring details could use some beefing up, and we will do this in the next revision of the manual. If you have questions, please call Hitachi's Technical Support Line at 914-333-2900.
Paul Curtis
Asst. Product Manager, AC VF Inverters
Hitachi America, Ltd.
  #27   Ban this user!
Old 03-26-2007, 01:56 PM
mactec54 is on a distinguished road
Hi Paul great to see Hitachi Product Manager on this site.
I think there is a biger problem as the drive wires L1 L2 L3
were not used the power was applyed to the +1 + -
where you would put your Braking resistor I think that is
were the jumper is that was being talked about. I may be wrong
on this but thats how it reads in the differant posts I have
read
Mactec54
  #28   Ban this user!
Old 03-27-2007, 08:22 AM
Last week I sent a letter to Hitachi about the confusion associated with their instructions for single phase hook up of their VFDs. I directed them to this discussion thread and asked then to respond. They immediately sent me this attached PDF file. I see that they have also written a post to the group. This is very good to see.
File Type: pdf AN032404-1_Sizing_for_Single-Phase.pdf‎ (67.6 KB, 170 views)
  #29   Ban this user!
Old 03-27-2007, 08:26 AM
Letter from Hitachi
Here is the personal reply I received from Paul Curtis. See my original letter below.
Dear Mr. Cunningham,
Thank you for your recent email. While we deeply regret any confusion you had, we do truly appreciate your feedback. We make every effort to produce a thorough and clear instruction manual. I’m sure you can imagine, preparing a manual for such a product is a complex task, and sometimes details can be overlooked. We value input from customers such as you to continually improve our documentation. We will make sure this matter is addressed in the next revision of our manual.
Again, thank you for taking the time to write to us, and please feel free to contact us if you require any further assistance.
Sincerely,
Paul Curtis
Assistant Product Manager
AC Inverter Products
Tarrytown, NY
Technical Support Line: (914) 333-2900
http://www.hitachi.us/inverters
From: bilinghm@bellsouth.net [mailto:bilinghm@bellsouth.net]
Sent: Friday, March 23, 2007 3:49 PM
To: #HAL_inverterinfo
Subject: CUSTOMER SUPPORT: Hitachi SJ200-015NFU
You have received a new global support request:
First Name: bill
Last Name: cunningham
Phone: 770-632-5711
Email: bilinghm@bellsouth.net
Country: United States:us_email
From web page:Hitachi Global Support Form
Subject: Hitachi SJ200-015NFU
Product Category: AC Variable Speed Drives
Question: I recently purchased a Hitachi SJ200-015NFU Variable Frequency AC Inverter Drive for use in my home machine shop. I am shocked by the extremely poor wiring instructions supplied with this unit. I will be using the inverter with single phase 240 VAC power. The section that discusses the proper single phase wiring of this expensive and complex unit is approximately one sentence on page 2-19. There is no photo of the proper wiring (as there is for three phase). This lack of information can lead to inncorrect wiring and expensive damage to the unit. You do your product and your customer a disservice with such poor instructions. See a discussion of this at: Apparent issue with SJ200 & Leeson 3ph 2HP motor You need to do something about this!
  #30   Ban this user!
Old 01-13-2008, 11:00 AM
QSIMDO is on a distinguished road
This thread has been of tremendous value to me as I just bought the VFD in question.
Hope everything worked out well for the thread originator.
However, as I was reading the PDF with the info from Hitachi on "Sizing Three-Phase Inverters for use with Single-Phase Supply" I was taken aback by the sentence "The rule of thumb Hitachi recommends is to start with the (motor's) nameplate full load amperage (FLA) rating and double it. Then select an inverter with this doubled continuous current rating."
I'll be driving a 3 hp, 3~ Baldor VM3559T dual voltage motor which, if I'm reading the plate correctly is "7.8-7.4-3.7".
So "15.6" for the motor and the VFD is rated at 11?
Now I don't really -need- 3 hp, but the motor came so cheap.....ahh well.
So does this mean buying a 2 hp then?
  #31   Ban this user!
Old 01-13-2008, 11:24 AM
wildcat is on a distinguished road
Give a call to the Hitachi tech support for clarification. When I talked with them about this they said that derating was not necessary. The sentence below may provide clarification as well. Perhaps for 3HP and less if you buy a VFD rated for single phase you are fine... perhaps only when you go beyond that and/or buy a three-single phase only VFD that there is a need to derate. I sure would given them a call though. I've had nothing but great response from them. Not the usual tech support.
Although Hitachi does not actually offer inverters above 3 hp specifically designed for and rated for single-phase operation, single-phase power can in fact be used with larger rating inverters, as long as care is taken to properly upsize and apply the inverter.
  #32   Ban this user!
Old 01-13-2008, 06:04 PM
I have their number right here, I'll call tomorrow.
Of course, hind sight tells me I should have checked all this out BEFORE I did a ton of work to adapt the motor.
Senior moment, eh?
Issue at low power.... WilliamD Laser Engraving & Cutting Machines 2 12-01-2006 11:44 PM
Homing Issue Moondog Machines running Mach Software 3 07-29-2006 10:23 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
Parallel Relay Board & Z-motor brake issue Liv2fish2 Machine Problems, Solutions , Wireless DNC, serial port 0 02-06-2006 11:35 AM
THC Issue Aldoseri CamSoft Products 3 01-31-2006 04:33 AM
