Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 11-23-2006, 01:07 PM
bradodarb's Avatar
bradodarb is on a distinguished road
Yaskawa Varispeed 626 MT
Hope this the right place..........
I just got a 1983 Ikegai lathe with a Yasnac 2000g control and a
Varispeed 626 MT CIMR-MT-CA-3T running the spindle. After hunting down the parameters and getting them plugged in I reduced the error codes down to 1. Spindle error. The control manual said it was a fuse or thermocouple that was causing the alarm. I can't find this to be the case. The drive has a vertical bank of round LED's that I can only assume to be some sort of diagnostic display predating the Digit type LED's on modern drives.
I downloaded the oldest Varispeed manual from Yaskawa but it is for the
MT-II, I must have the MT-I? The MT-II has a 5 digit LED display that actually sends error code numbers, mine must do the same with combinations of single LED's.
BTW- I am using a smaller phase converter than I will be when I fire up the spindle, I am just trying to get the control back into shape and possibly jog some servos! Maybe the small phase converter is not allowing the inverter to completely come online?
Please advise-
Brad
Old 04-27-2009, 08:38 AM
cnc_guru_guy is on a distinguished road
You can download the MT1 manual here:
http://www.yaskawa.com/site/dmspindle.nsf/link2/TKUR-5EKSVU/$file/NTR0010.pdf
Hope this helps...
CNC Guru Guy
