Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 11-13-2006, 07:49 PM
gearsoup is on a distinguished road
Another RPC question....
Are all rpc's created equal?
What is the main difference between a Phase-A-matic RPC:
http://www.use-enco.com/CGI/INSRIT?PMAKA=297-3813
and this unit:
http://www.americanrotary.com/product.php?productid=12
Does each unit have it's own advantages/disadvantages?
I am looking at powering a 2001 Johnford SV-40 with a 15hp spindle. It isn't something I want to fool around with, but the $$$ they want for a phase-a-matic is more than I was budgeting for....
Old 11-13-2006, 08:14 PM
Al_The_Man's Avatar
Alot of people swear by the Phase-A-Matic, AFAIK one of the main differences is that the motor is suposedly made for RPC use.
I built mine and so far has worked OK.
I guess it is one of those 'You pays your money and takes your choice'.
Usually the spindle is less critical if the control and servo's run off of single phase in the machine, they can be fed from the main feed pair, then it is usually less of a possible problem.
If the servo's are three phase fed, then this can create issues.
Old 11-13-2006, 08:18 PM
hmmmm.... how does one find out when one hasn't actually purchased the machine yet......
