Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-09-2006, 01:04 PM
CATCH22 is on a distinguished road
MITSUBISHI FREQROL A500 INVERTER FR-A520-3.7K does anyone know if you can run 1 phase
ive read the info on this model and cant come up with an answer to weither or not you can run this model with single phase in and 3 phase out.if anyone can help me out with this that would be great.thanks mike MITSUBISHI FREQROL A500 INVERTER FR-A520-3.7K
Old 10-09-2006, 01:19 PM
Al_The_Man's Avatar
The manual should indicate it, it should be on the MEAU site.
I have run the smaller FR-A200's on single phase with no problem.
This will be a 480/575v model will it?
That is around 5 hp model so it may be marginal, but it should not hurt to try it all you do is hook the single phase to R & S terminals.
