| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
I'd like to run a fractional hp, single phase induction motor to drive a small model makers lathe. Can I use a vfd to give me speed control ? If the answer is yes, has anyone built one, as the cost of a new one is several times more than the cost of my lathe and motor. John
__________________ It's like doing jigsaw puzzles in the dark. Why is there always more error than trial ? |
| fka - are phase converters the same as vfd's then ? I didn't think so. Geof - neat, thanks for the idea. John
| Greybeard, my mistake, I meant vfd. The rest still applies. It's just confusing how many flavours of electricity is used on this planet. Take in consideration that a drilling machine produces a considerable greater amount of noise than a vfd'd lathe. |
To take geof's idea further, the usual solution to speed control on small machines is a DC motor and a speed controller... have any unused treadmills lying around? Edited; can't type today.... |
) I'll buy greybeard a couple of beers next time I am in England. |
| Ok guys, Geof wins on pints ... One thing though, and perhaps I should have spelt everything out, I did say a single phase motor, so three phase is not in the frame. And I should have emphasised that the reason for choosing the induction motor out of the scrap bin was that it is virtualy silent compared with any brushed motor I have. John
| Hi greybeard, be carefull using a VFD on a small (1/4hp) induction motor. As you appear to be into model engineering and are using a table top type lathe, then the "want" from your end is a speed range from about 50 rpm for cast iron etc and 2000 rpm for small drilling and polishing. The problem is, induction motors run slow get HOT, and as you will be simulating a lathe in back-gear then the torque low down will only be achieved by pumping the amps into the coils in a virtual dead stall situation. The electric drill method will work but the whining of the motor will drive you nuts. If this is an option then try a vacuum cleaner motor, or angle grinder, modified, with a light dimmer switch rated at about 350 - 500 watts. Top speed of the vacuum motor is about 10,000 rpm so if you belt this down by vee pullies to 2000 rpm input then the motor will still get some cooling running slow. The best option for your case is to use the induction motor "as is", and arrange a variable VEE pulley drive to get speed change. They're not hard to make, and if you use standard vee belts, just use two variable pulleys in compound arrangement. This way you still get "dial up" speed control on the move and plenty of low down torque. Ian. |
#10
| The brushed motors you mention must be Universal type, as a true DC permanent magnet motor is very quiet, apart from a bit of brush noise which should be negligable. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#11
| Ian - thanks for reminding me about variable vee pulleys. I'd forgotten those as a possibility. Al - yes, the concensus seems to be that low speed end of the control is the problem area. I think I'd best stick with a mechanical solution. How about a Sturmey-Archer 3 speed hub as a gear box ???? ![]() Change the sprocket to a vee pulley ? John
#12
| Hi greybeard, "sturmey Archer" now that is cutting edge technology. They're not the easiest thing to mount up and don't give much speed range. Have you thought about a motorcycle gearbox. The four speed one is really compact and gives a speed range from about 1:1 to 1:4. I would strip the guts out and reassemble in a made up casing. Ian. |
