Most current VFD's under 5hp will run on single phase, you should make sure from the manual or manufacturer first that this particular model will, the ones that don't are getting rare.
If you already have the VFD, hook it up and try it on 1ph, it should let you know if it doesn't like it.
Normally the inputs are labeled like R-S-T for the 3ph in. Typically you would use R-S for the 1ph.
LinkBack URL
About LinkBacks
