Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 03-20-2006, 10:29 AM
GalaticDan is on a distinguished road
Porter cable 7519 speed control?
I've been thinking about buying a Porter cable 7519 router. It's the 220volt version I was interested in using. Porter cable gave me part no. 22-7519-60 and it's a special order through my local hardware store. This is a single speed version of the 7518. The 220volt armature coils enables it to run cooler or so the techie at Porter Cable said when I called about the part number.
Ok, I'm seriously interested in this router but want to know if any of you guys have managed to control the speed of this 3 & 1/4 horse power beast. Theres no feed back on it, I think? So I was thinking about a simple analogue control via current or preferably voltage say 0-10volts = full RPM. Is this possible? and what drive to use?
Dan
Old 03-20-2006, 11:43 AM
vacpress is on a distinguished road
i am looking at a similar issue. Ive got a 120v portercable 6902. I want to build a closed loop RPM controller for it. I beleive this will be fairly easy once I figure out what sort of driver circuitry is needed for these single-phase AC motors. Were it DC this would be easy - H Bridge, PWM. However, as it is, I havent got a good idea the best way to do this. Do you?
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
Old 03-04-2008, 09:42 PM
woodman08's Avatar
woodman08 is on a distinguished road
router 7519 220volt
I also have been looking for speed control for the above router with no sucess .
I use some large diameter bits and thats scarey.
I would like to slow it down,but it might be the same cost to replace the router with a 120v one
Old 07-11-2008, 07:58 PM
gfc62's Avatar
Platinum Member
gfc62 is on a distinguished road
Any updates on this question? Has anyone looked at the speed control circuit in the 120V router to see if it's something that can be re-engineered?
I'd like to figure out how to control my 7519 from Mach 3 using a DC speed controller with some sort of feedback mechanism.
Old 07-11-2008, 09:51 PM
woodman08's Avatar
if you're still interested in that router let me know,I have that model to sell
stankern@BMTS.COM
