| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
My mill motor is 2hp 600v 3ph. So I have a 2 hp ideler motor with a start and some run caps. I have been able to get the rpc working with balanced voltages. I then have a power transformer hooked up to the 220 in giving 575 out. Now when I start the system up with my latest cap configuration at the rpc I get about 215 a-c and 220 b-c for the primary. At the secondary I get 565 and 590v. When I switch on my mill it seems a bit slugish starting and will only start in one direction. However the direction it does start in when I test all the voltages primary and secondary they are all balanced 220 and about 570. I checked the amperage at the mill motor with a clamp meter and the x and y legs are drawing about 1.2 amps and the z leg is 0.03. Any thoughts of where I need to go from here? |
| Something is open circuit, a capacitor is low on value due to internal failure or become shorted. Has it ever worked? Here is what worked for me, but no power transformer and I only got 380vAC but was OK for my application running smaller motors. You just scale it up. I used a 3 phase DUAL VOLTAGE motor as the converter. Delta connection: Each of 3 legs were 2 windings in series, with a star point. output. . U cap winding. | input.. . X winding. | winding/ \ winding cap.. Z. . .Y input wind./ . . . \ winding out W . . . . . V out sorry for crappy diagram. html sucks. 240v AC input X and Y Output U,V,W 380vAC 1.5A 8uF capacitor from U to Z Turn on power. Kick start the motor with my foot. You could use a small motor to spin it up, but once running, who cares. It was used to run all the rapid feed motors, (3/4HP). A flywheel would be a big bonus.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. Last edited by neilw20; 01-29-2012 at 11:40 PM. Reason: typo |
| I am just hooking this up for the first time. Its odd though because the idler motor i have is a 3450rpm motor which is supposed to be hard to start and better at balancing the voltage. It starts in one second and runs ok. I dont know why i have voltage on the 3rd leg of the 600v transformer but cannot draw any current. Myabe i just need more capacitance to the 3rd leg? |
| I just measured the current at the idler and L3 is very low with the mill running or not. However L3 going into the transformer is 2.5 amps. When I disconnect the transformer the idler shows current at all three legs. So my transformer seems to be not allowing the idler to do its job. At this point I am assuming I need more capacitace. Any one know how to size capacitors for a rpc with a transformer after? |
| Need Help!- drawing ball mill radius | jrmach | BobCad-Cam | 8 | 09-23-2011 08:02 PM |
| Looking for a drawing of the mini mill | tootalew | Benchtop Machines | 9 | 10-15-2010 08:03 AM |
| Need A Quote- RFQ: Mill work for small alumium pieces. Drawing attached. | Siubee | Employment Opportunity | 2 | 05-17-2010 02:47 PM |
| Need Help!- How do I edit a DWG drawing so I can add my toolpath drawing. | SpeedsCustom | Autodesk Software (Autocad, Inventor etc) | 13 | 10-01-2009 10:32 PM |
| Need Help!- converting imported part drawing to mold drawing | msomerville | BobCad-Cam | 6 | 08-29-2008 06:56 AM |
