| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Hi all, I am wanting some help to build a simple and more importantly cheap speed controller for a 240v 50Hz single phase 2 pole .55kw motor. I have found a circuit on a ST semiconductors pdf(page 6) http://www.st.com/internet/com/TECHN...CD00003856.pdf The circuit uses triggering by pulse train synchronization by the mains voltage. Do you think something like this will work on my motor? My next question is what value components would I need? (capacitor/resistors/pot and Triac's) Would these Triac's suit? Triac To220f Logic 600v 12a 10,10ma Or non Logic Triac http://www.rapidonline.com/Electroni...-50-ma-47-3594 Here are 2 screen shots of the pdf and the motor specs(highlighted with red stars) Thanks very much for your input Ceefna |
| Your motor sounds like it might be a split phase motor as shown in fig9 which shows a fan type motor application. What is your actual application? If this is a lightly loaded application such as the fan shown, it might work, but i would be inclined to look at at other options if the application is more demanding. These type of controllers do work in the likes of ceiling fans etc, you could pick one of those up and try it. 1ph induction motor speed control can be very touchy in some applications so more would have to be known before definite recommendation can be made. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 01-25-2012 at 10:25 PM. |
| direct driven or belt driven | jeremy0203 | Benchtop Machines | 5 | 07-26-2011 11:23 PM |
| closed loop vector control frequency inverters for energy saving & process control | greendriv | Product Announcements & Manufacturer News | 0 | 02-10-2011 08:05 AM |
| Cutting speed locked to Z torch height control speed | Beefy | Mach Plasma / Laser | 1 | 02-14-2010 05:14 PM |
| Variable frequency drive for high speed spindle | icestation2 | General Electronics Discussion | 3 | 03-19-2009 12:20 PM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
