Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-31-2005, 02:16 PM
loves80z is on a distinguished road
AC unit -> rotary phase converter?
I am taking an old (1945) AC unit apart to turn it into a rotary phase(1 to 3 phase) converter and exhaust hood. I am trying to figure out what I need to do to start the motors. It had a thermostat at one time. Can I use a light switch or something simple. The top box is the breaker and slow blow fuses. What are the other 3 boxes?
Kevin
Name:	ac stuff 2.jpg‎
Old 10-31-2005, 03:54 PM
Al_The_Man's Avatar
Looks like some kind of contactor with either a time delay or overload, what does the square D units have on them? If it was a AC unit it might have been a start time delay.
Old 10-31-2005, 05:49 PM
I am taking it apart now. I will scan the tags and post them tomarrow.
Old 11-01-2005, 10:18 AM
Here are some scans. I've been reading these for a few weeks and don't understand how to make it work or exactly what it is I'm seeing here.
Name:	1hp motor contactors and starters 1.JPG‎
ID:	11608   Click image for larger version
Name:	1hp motor contactors and starters 2.JPG‎
ID:	11609   Click image for larger version
Name:	7hp motor contactors and starters 1.JPG‎
ID:	11610   Click image for larger version
Name:	7hp motor contactors and starters 2.JPG‎
Old 11-01-2005, 10:28 AM
close up pics
The yellow blue and red come from somewhere in the building (Thermostst?)
Name:	between sm and bg motor.JPG‎
ID:	11612   Click image for larger version
Name:	lg motor.JPG‎
ID:	11613   Click image for larger version
Name:	sm motor.JPG‎
Old 11-01-2005, 10:33 AM
Al_The_Man's Avatar
You should be able to use the contactor, depends what size motor you are using, it looks like it has a 220v coil so you should not need a control transformer, I made mine this way, there are some previous posts and links I have posted, a search of the forum should get them.
You will need a couple of good quality pushbuttons rated at 250v, as well as the necessary capacitors.
Old 11-01-2005, 11:44 AM
Thanks Al,
I searched the posts and downloaded the jpg's from Metalworking.com. Part of what I don't understand is Do I need a start capacitor. I didn't see one on the machine. I think I can blindly hook this thing up the way they had it, but I don't understand it. I have a hard time moving forward when there is something I don't understand. The motor is 7hp and the boxes were all connected to the 7hp and a 1hp motor.
I will do reasurch on contactors and see if square D has any info specifically on these and bump when I am done.
Kevin
Old 11-01-2005, 12:22 PM
Al_The_Man's Avatar
The contactor is size 0, which according to code is good for 3hp on 230v. You should by rights be using a size 1.
You need a start capacitor if you want pushbutton start, this should be motor start grade, intermediate use, as opposed to the run caps, which should be continuous rated.
Others have used a crude way of starting by pony motor or rope pull start to get the rotor turning initially.
The P.B. start is more convenient.
Old 11-01-2005, 02:03 PM
Gold Member
HillBilly is on a distinguished road
They were probably using a single phase 1hp motor as a pony motor to get the three phase motor turning. Once the motor was spinning they would apply single phase power to the spinning three phase motor ( A three phase motor will run on single phase after start up.). This arrangement does not use a start capacitor and run capacitors are optional.
Darek
Old 11-01-2005, 03:45 PM
I think I am starting to understand what I have.
Here's what I'm gathering. I think they were starting with no cap. I will want one so I get less surge. I should use the larger contactor or for the 7hp motor. It has thermal overload. Bonus. I should use a mamentary push button 220 rated to jump start.
I will draw a schematic of what they had and a schematic of what I think I need and repost.
Kevin
Old 11-01-2005, 04:48 PM
Al_The_Man's Avatar
Here is my schematic if it helps.
  #12   Ban this user!
Old 11-01-2005, 05:28 PM
It's starting to come clearer. I see how the startup and E-stop work. I think I want to do what U have in your schematic. I've seen things like that but now I am begining to understand. Only one question. Is 1CR and MC1 the same as the contactor for the large motor, or do I need a seperate device for MC1 (the contactor I have) and 1CR?
