Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
  #13
Old 11-01-2005, 04:40 PM
Al_The_Man's Avatar
ICR is only picked up momentarily for the start operation MC1 is the main three ph contactor. 1CR is just any small control relay with a 220vac coil. You also need an auxiliary retaining contact on MC1.
The start PB only needs to be held for less than a second otherwise you may trip the O.L.
BTW Looking at the schematic again, it is a bit misleading as I have a corrected version, 1M,MC1 & MCR are one and the same, 1CR is separate.
  #14   Ban this user!
Old 11-01-2005, 04:57 PM
loves80z is on a distinguished road
Does 1CR have 2 seperate contacts? One from 12 to l3 thru cap and one to MC1.
Kevin
Thanks for the help.
Old 11-01-2005, 05:05 PM
Al_The_Man's Avatar
Yes, it operates the start cap momentarily and initializes the pick up of MC1.
  #16   Ban this user!
Old 11-02-2005, 06:51 AM
I made a diagram last night. Here it is. Can I do it like this? The one momentary button turns on both the startup coil and the motor contactor. I want to add the light across the motor contactor relay. BTW I'll be running a 1hp mill off this.
Kevin
Name:	PHASE DIAG2.JPG‎
Old 11-02-2005, 04:13 PM
Al_The_Man's Avatar
It looks Ok to me, mine is a 7.5hp unit btw.
  #18   Ban this user!
Old 11-02-2005, 04:23 PM
Thanks a lot Al
U da Man!
Kevin
