Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 01-03-2012, 11:04 AM
rkaasa is on a distinguished road
HY02D223B Spindle acceleration (E.OC.n)
Hi
Over the last few weeks my homemade CNC router have been taking shape and last week I was able to do the first test runs. So far I am very happy with the results, but I do have a problem with my eBay HY02D223B inverter.
When I try to start the spindle with a high RPM setting (close to max 19000-24000) I get the E.OC.n error. My spindle is 6000-24000RPM 2.2kw. It is most likely caused by the high inrush current at startup. I have therefore tried to slow down the acceleration (PD014 Accel. Time 1) Manual says 0.1-6500 seconds. I have tried many settings ranging from 1 to 6500 but there is no change in spindle acceleration on startup. It seems like the acceleration is independent of PD014 setting. (PD015 Decel. Time is affecting the deceleration time as expected).
I am able to run the spindle at max RPM if starting it at a lower frequency and increase the frequency while spindle is turning. I assume the spindle operation is normal in every way except startup at high RPM. I have tested it milling aluminum with a 10mm end mill slotting 2mm deep with no problems Have anyone else had problems setting acceleration time on these VFDs?
Display tells me ASR 1.0 and UR 1.00 when powered is connected.
Any help would be appreciated!
Reidar Kaasa
ID:	149354   Click image for larger version
Old 01-03-2012, 11:41 AM
hub hub is offline
hub is on a distinguished road
Try setting PD020. Any difference?
http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html
Old 01-03-2012, 12:09 PM
The default value for PD020 was “0080.0” I changed the value to “0850.0”. Cannot hear any difference in acceleration and still the E.OC.n error during high RPM start. The default value of 80 should also be a rather slow acceleration? It sounds like the spindle tries to accelerate in less than a second.
Old 01-03-2012, 12:26 PM
hub hub is offline
Ok, how are you using the VFD? External control of start/stop & speed? Or are you using the VFD panel to start/stop & set RPM manually?
How do you have it connected?
Old 01-03-2012, 12:40 PM
I will eventually connect the VFD to Mach3 via RS485. At this time I am using the VFD onboard control panel. No external connections at this time, except power inn and the four wires for the spindle. That’s why I used PD014 in the first place. I suspect some software issues. I have actually not thought of trying a factory reset. I may try that to see if it helps on this problem.
Old 01-03-2012, 01:57 PM
I did a factory reset PD013 – 08. Changed the required parameters and tested again. Tried to start the spindle and ended up with an E.OC.A error. I changed a few values again and managed to start the spindle. This fixed the problem. I am not sure what was causing the problem in the first place.
I am now able to change the acceleration time via PD014 and the E.OC.n error went away with the longer ramp up time.
Sorry for wasting your time on this problem! Appreciate your help!
Old 01-04-2012, 12:16 PM
hub hub is offline
Glad that you got it fixed
Need Help!- How can i change the acceleration on the spindle (Huanyang 2.2kw)? Vegabond Phase Converters and VFD 8 09-05-2011 01:38 PM
Need Help!- dx-32 Spindle Acceleration/Deceleration Problem cybermachineman Bridgeport and Hardinge Mills 4 05-22-2011 01:01 AM
X2 and G540 spindle acceleration rate. TXFred Benchtop Machines 0 03-02-2011 06:30 PM
Problem- "over current/ field loss" on spindle acceleration or deceleration rolandkra Fanuc 11 01-19-2011 06:49 PM
Problem- Spindle speed at 25% on HY02D223B George Phase Converters and VFD 2 09-11-2009 09:36 AM
