Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 01-02-2012, 01:24 PM
KEYTEEM is on a distinguished road
Hitachi X200 OPE-SR keypad
Has anyone hooked one up and used the "ope-sr"
keypad for their vfd?
The owners manual does not show the wiring for the
hook up between the drive and the ope-sr.
It does show that pins 5+6(rcv+trns data), are needed for a modbus configuration and to not connect the others, but no wiring diagram for just using the keypad. So i tried this and
have just the 5+6 pins wired from the keypad to the drive and the ope-sr won't function.
common sense tells me to wire all 8 pins on each rj-45 alike and call it quits but I hate taking chances.
thanks for your help
Dennis
Dennis
Old 01-15-2012, 07:49 AM
for future ref,,the standalone keypad is a plug and play unit.
The cable needs to be a standard cable,cat5,and no program changes
on the the drive.
Dennis
Old 01-15-2012, 08:31 AM
mike_Kilroy is on a distinguished road
sorry for the confusion! Glad you got it working and thanks for the feedback!
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
HITACHI X200 settings 15mgtar DIY-CNC Router Table Machines 92 05-23-2012 10:54 PM
Keypad/Touchscreen mmckell Cincinnati CNC 2 02-07-2012 12:05 PM
Hitachi X200 to G540 - PWM speed control and run BloomingtonMike Phase Converters and VFD 0 12-29-2011 10:52 AM
Hitachi X200-022NFU Power Requirements Kent23 Phase Converters and VFD 0 09-28-2010 10:36 PM
Hitachi X200? fritts Phase Converters and VFD 2 12-26-2008 09:06 PM
