Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 11-18-2011, 10:19 AM
BanduraMaker is on a distinguished road
Q regarding line reactors
So, I have a teknomotor spindle with a Hitachi WJ200 VFD and in conversations with the tekno rep, he was always pushing me to add a line reactor to the system saying that it will extend the longevity of the spindle by quite a bit and that just everything would be better. They don't distribute line reactors so I'm assuming he was being honest. A line reactor was only $100 so I picked one up.
Question is on the wiring and mounting. I currently have the thing bolted to my work bench and it is not grounded. There is no separate ground lug on the transformer.
Is this a disaster waiting to happen or am I ok with this setup? Do I need to make a grounded metal box for this and tie it to the chassis of the reactor or anything?
TIA,
-Andy
http://banduramaker.blogspot.com
Old 11-18-2011, 10:33 AM
Al_The_Man's Avatar
I am assuming he recommended using it between VFD and motor?
You should bolt it to a grounded chassis or enclosure or run a ground wire to it if you are leaving it bolted to your bench, which doesn't sound very safe?
The ideal is close to the motor.
Old 11-18-2011, 10:42 AM
The upload photo thing wasn't working but here's a (lousy) picture of the setup.
I could shorten the run to the spindle by about 3' maximum. I could also throw a ground wire from the wirenut to the reactor without too much difficulty. Finding an enclosure would be a bit more difficult but possible.
-Andy
Old 11-18-2011, 11:03 AM
Al_The_Man's Avatar
The enclosure is up to how safe you feel, it does not affect the operation but your VFD and motor frame should have a ground conductor, the one you should have to the VFD would be closest to hook up to.
Old 11-18-2011, 11:09 AM
Yes, the motor and the VFD do indeed have a ground. You can see the green wire with the yellow wire nut next to the reactor - that comes from the 220 plug that feeds the VFD.
I'll probably enclose it at some point.
-Andy
Old 11-18-2011, 03:00 PM
mike_Kilroy is on a distinguished road
I can't tell from the pix if it is between the motor and vfd or on the 3ph input to the vfd..... would be good to know which it is....
PS: wow, your website showing ur bandura's is neat!
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 11-18-2011, 03:05 PM
Al_The_Man's Avatar
I wondered, but when Andy mentioned shortening the run to the motor I assumed it was on the motor side.
Old 11-18-2011, 03:47 PM
Yes, I'm running single phase 220v into the VFD. VFD 3phase out goes to the line reactor then to the spindle. I highly doubt that the 3 feet of length I can get rid of between the reactor and the spindle is going to make much difference at all.
-Andy
Old 11-18-2011, 05:40 PM
good enough. yes, 3' less length out of like 13 total will make no difference to anything.
BTW, ur decision to add this inductor wasd good one; the spindle motor mfgr was 100% correct it will help cool ur spindle motor at any given load and it should extend the life of your motors insulation too. we use output reactors like this when we need to squeeze every ounce of power out of a given spindle motor. there is plenty of scope picture docs as well as temperature measurements that prove this helps - prob gets u another 8% power out the motor compared to same system w/o the output choke.
Old 11-19-2011, 07:58 PM
I ran a couple hour job today and the spindle was noticeably cooler. Not that it got super hot before but, I have a stick on thermometer on there and it barely got off the second temp after several hours of running.
I'm thinking it was $100 well spent.
-Andy
  #11   Ban this user!
Old 11-20-2011, 06:07 AM
andy, please give us the rest of the data to complete the picture!!!!!!!!!!!!
when we generally use an output choke, we get about 8% more (maybe 8% cooler motor than w/o it) - but we start with a vfd that has probably 100% smoother output current than these small vfds like u used!!!
so how MUCH did it help on YOUR low cost wj200 vfd?? PLEASE give us the **BEFORE** temp from a similar job so we can the whole improvement!
  #12   Ban this user!
Old 11-20-2011, 07:18 AM
Hi Mike,
I don't really have quantitative data on this but I do have a stick on thermometer on my spindle. When running a long job, my spindle temp sticker would start at around 40o C after 15 to 20 min and creep up from there hitting a maximum of around 50o C. Yesterday, It didn't make it past 45.
Mind you, I'm not really loading the spindle too hard though either - I think if I was more aggressive with my cuts, it would probably make a bigger difference.
-Andy
Need Help!- way to see the g code comands visualized line by line in Bobcad? 777funk BobCad-Cam 3 04-07-2011 07:48 PM
Line conditioners for CNC Equipment and poor line conditions WSS CNC Plasma and Waterjet Machines 0 01-13-2011 08:07 PM
Dm2400 Line By Line Execution???? andrewtub Benchtop Machines 6 01-25-2010 10:28 PM
Line Smoothing, point /line no identification dz1 Visual Basic 8 12-15-2007 05:03 AM
line arc line THE GREAT ONE General Metalwork Discussion 3 01-23-2006 02:43 PM
