Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-26-2011, 09:46 PM
Prl motorsports is on a distinguished road
good VFD for bridgeport s1, 3ph in 3ph out?
i'm sure it has already been asked, but i'm new to the VFD and had some questions on whether or not what i want to do is the best route to go or not.
We just picked up an early 70's bridgeport series 1 9x42 with the 1hp step pulley head on it. i like the reliability of the step pulley head, but i don't like the limited speeds available as well as having to change the belt for the adjustment.
the shop we're in has 240v 3 phase service, so i could just wire it up and not worry about it, but i've been reading about the vfd's and i'd like to use that for the speed control.
the questions i have are:
1. is this a smart way to go, or does it end up being more of a headache in the long run.
2. can someone point me to a good vfd to use with this mill?
3. should i get a braking resistor for when i'm tapping on the mill? or will the internal resistor in most vfd's be enough to quickly go from fwd to reverse?
thanks for the help
jason
Old 11-12-2011, 02:40 PM
gta/spec is on a distinguished road
best investment for your mill
I would definatly get a vfd for your mill. The added control that a vfd gives you is amazing.
I would recommend it to any Bridgeport user, but especially guys that have pulley heads.
Tapping, indicating, tramming, not having to use back gear, % spindle load display, immediate stopping and reversing, plus variable speed.... awesome.
Old 11-12-2011, 02:57 PM
Al_The_Man's Avatar
There are a few things to consider especially when tapping, is this rigid tapping or floating?
Rigid obviously requires stricter control and synchronization with the Z axis.
Depending on the controller, Rigid also requires an encoder on the final shaft.
If non-CNC then things are a little simpler, but VFD is definitely a plus, I have tended to pick up the higher end VFD off ebay rather than get the cheaper new or non-NOS type.
Mitsubishi or Telemecanique Altivar are nice.
Would a Bridgeport J-Type be a good candidate for CNC conversion? crazyman Bridgeport and Hardinge Mills 7 11-27-2011 03:21 AM
Bridgeport, Hendey, Gould&Eberhardt - Good Deal?? MusicMan General Metal Working Machines 0 07-15-2010 12:44 PM
Retrofitted Bridgeport CNC on Ebay, good price? Skyshark Bridgeport and Hardinge Mills 9 08-31-2007 05:18 PM
phase ultract 2 ac servo motor - good for series II Bridgeport conversion? cezzo Servo Motors and Drives 0 08-05-2007 10:00 PM
Bridgeport Interact 412 w/Hedenhain control. Good machine? SRT Mike Bridgeport and Hardinge Mills 3 06-25-2006 08:13 PM
