Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 10-09-2011, 03:21 PM
bogiestl is on a distinguished road
Is there a complete idiot's guide to motors?
My mentor is telling me that I'm going to need to go with a three phase system when I open my own shop, and that it's more efficient to use the phase converter to run the machines than it is to use "regular" 230... The shop is going to be basically just a garage-type setup for small product runs, prototyping, etc...
Old 10-09-2011, 06:18 PM
mike_Kilroy is on a distinguished road
sounds like u need a new mentor friend.
if u want to list the possible motor sizes u envision, you will get lot of crap but also lots of good ideas here.... list away!
Mike (at) KilroyWasHere.com -- machine tool servo repair, retrofit
Old 10-09-2011, 10:31 PM
Al_The_Man's Avatar
It depends on the size of the machines, power demand etc, for small machines 240v 1 ph with 3 phase spindle motors and VFD can be sufficient.
Some of the small machines sold by vendors in these forums also have BLDC and DC brushed spindles, neither of which require 3 phase supply.
Old 10-10-2011, 12:09 PM
keebler303 is on a distinguished road
Normal US household power is 220V single phase (or split phase, some people call it different things, its the same). Most industrial equipment uses 3 phase motors because they are more durable, more efficient and cheaper to build/buy. So you need to turn your single phase power into 3 phase power to run 3 phase equipment.
If you only have one or two machines, Using a VFD for each machine may be more cost effective. If you have several machines (air compressor, dust collection, mill, lathe, grinder, etc. etc. then you are probably better off buying a single rotary phase converter to power the whole deal. You would trun on the phase converter and leave it on while you were working in the shop, then you can turn your equipment on or off at will.
Old 10-10-2011, 12:22 PM
Al_The_Man's Avatar
It should also be noted VFD provides variable speed of any 3ph motor it is applied to whereas the RPC or SPC will not.
Is there a complete idiot's guide to motors? bogiestl Stepper Motors and Drives 2 10-01-2011 12:38 AM
Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China Ling Product Announcements & Manufacturer News 2 07-12-2009 04:10 AM
Guide for determing screw and motors? gasmasher DIY-CNC Router Table Machines 5 03-25-2009 05:32 PM
Drill Press Speed Guide, Band Saw Speed Guide zerodegreec General Metal Working Machines 0 02-27-2009 12:12 AM
Just IN- COMPLETE TAIG MILL, CONTROLLER, 425ozin MOTORS, PC, MACH 3. READY TO RUN at $2600 blurrycustoms Product Announcements & Manufacturer News 2 10-26-2008 01:36 PM
