Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 09-18-2011, 02:53 PM
Wanna be
Hack is on a distinguished road
Not sure what wire goes where!
I am putting some finishing touches on my homemade mill and I am trying to get Mach 3 to control the spindle motor. It is a 220v 3 phase motor and I have been using a 110 single phase to 220 3 phase vfd for control.
I was looking to run the wiring from the breakout board (CNC4PC C11G) to the terminal stip on the VFD, but I am not sure what wires go where.
Below is what I have so far, but I am not sure if it is right.
From the Breakout board, I have 6 wires: 0-10VDC, ground, and 4 wires from the relays. I have the 0-10VDC on terminal 5 of the VFD, ground on terminal 2, 2 of the wires from the relays on terminal 13A and 13B (forward and reverse), and I am not sure where the other 2 wires from the relays go (the are labeled V IN on the BOB) and in some of the wiring diagrams from CNC4PC they appear to go to a "logic common terminal" or "DCM" depending on the VFD they are referencing. These relays are Electromechanical and can either be NO or NC. I currently have them wired NO.
So, do I have the correct wires going anywhere near the correct terminal? Where do the last 2 wires from the relays go?
Any guidance is appreciated. I don't want to fire this thing up until I know it is right.
Dan
I have made an excel spreadsheet up to show what connections are available on the VFD.
Check out what I am working on at www.routerbitz.com!
Mitsubishi wire type setting for zinc coated wire Futurewire EDM Machines 1 01-26-2011 03:47 AM
Mitsubishi wire type setting for zinc coated wire Futurewire EDM Machines 2 01-25-2011 06:49 AM
Running stepper motor wire with router wire? basskitcase DIY-CNC Router Table Machines 2 02-19-2010 10:18 AM
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 04:34 PM
How to wire an 8 wire stepper motor technosteve DIY-CNC Router Table Machines 1 01-16-2009 05:01 PM
