| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
| Hello. What PDxxx do i need to change on, and how is it work? I have read in the manual, but i don`t understand it correct.. Thanks. Robert.
__________________ My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html |
| Ok, that's a very bad manual, missing a lot of descriptions... There is not mention (that I could find) that says what is the difference btw accel1 - accel4 .. So, just try which one works, start from 1. Set these: PD014 Accel. Time 1 0.1~6500.0S * PD015 Decel. Time 1 0.1~6500.0S * PD016 Accel. Time 2 0.1~6500.0S * PD017 Decel. Time 2 0.1~6500.0S * PD018 Accel. Time 3 0.1~6500.0S * PD019 Decel. Time 3 0.1~6500.0S * PD020 Accel. Time 4 0.1~6500.0S * PD021 Decel. Time 4 0.1~6500.0S * Hub
__________________ http://www.cnczone.com/forums/cnc_wood_router_project_log/125895-my_diy_cnc_cnc2011_%3B.html |
Thanks , it work! ![]() Greetings from Robert.
| Maby you can take a look at this one too!? ![]() http://www.cnczone.com/forums/machin...ge_before.html Greetings from Robert.
There is a buffer memory that contains lines of G-code. They are already sent to the "controller" with the selected speed. It has to process them first I think. Not sure since I don't know the exact way of how it's programmed. Also, the step-pulsing is most likely a very high priority processing thread, and the speed change is likely a low one. Just guessing here, but that's the most likely reason in my opinion.
| Need Help!- Help Help Help - Huanyang VFd and spindle | PsychoPig7 | Phase Converters and VFD | 7 | 12-04-2011 09:19 AM |
| Spindle Change Over | astr | Bridgeport and Hardinge Mills | 7 | 10-17-2011 10:46 AM |
| Need Help!- dx-32 Spindle Acceleration/Deceleration Problem | cybermachineman | Bridgeport and Hardinge Mills | 4 | 05-22-2011 01:01 AM |
| X2 and G540 spindle acceleration rate. | TXFred | Benchtop Machines | 0 | 03-02-2011 06:30 PM |
| Problem- "over current/ field loss" on spindle acceleration or deceleration | rolandkra | Fanuc | 11 | 01-19-2011 06:49 PM |
