Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 08-07-2011, 06:57 PM
KEYTEEM is on a distinguished road
VFD' ?
I am looking into purchasing a VFD from Hitachi and notice their are only
three connections that go to the motor,unless I am missing something in
the manual.
The motor I'm using has 6 connections at the motor box, and there are really 18 in total at the motor,9 in+ 9out right. Will this motor still work with a VFD?
I imagine using t 1 2 3 for one direction and t 4 5 6 for another direction
so what do you do connect a switch between the VFD and motor?
I didn't think you were supposed to do that?
I asked another question regarding a static converter ealier but I think now
the smarter thing to do is look into a VFD. If it will work.
Dennis
Old 08-08-2011, 02:23 PM
Al_The_Man's Avatar
You most likely have a motor that is either dual speed or dual voltage.
You do not switch the motor leads for reversal, only three leads, or four counting the earth ground conductor.
The connections should be in the terminal cover.
Old 08-08-2011, 09:09 PM
The data plate does say hi + lo voltage and hi + lo speed.
Thanks Al
I'll check out the VFD intructions. Hitachi said it should
be no problem. I won't do any wiring untill I am positive
about it.
Dennis
Old 08-11-2011, 07:26 AM
mike_Kilroy is on a distinguished road
Dennis, I tried to send you pm but your mailbox is full. please make space and I will resend later. thanks.
