| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Hi All, I just took delivery today of a Chinese 2.2kw spindle with VFD (See link eBay - The UK's Online Marketplace) I have followed the instructions that came with the VFD which were to set PD13 set to 8 = Reset PD05 set to 400 (Max operating Frequency) PD04 set to 400 (Base Frequency) PD03 set to 400 (Main Frequency) I have done this but when I run at 400 Hz I seem to only be getting 11520 RPM rather than 24000. By the way I am reading the RPM by pressing the mode button so that the ROTT light is on, but I am not sure how the VFD would know what RPM the spindle was doing, so maybe the spindle is running at 24000 RPM PS. I have the 220V version of the VFD. Can anyone help me out here, have I missed a setting or does the VFD wrongly report the RPM. Regards Simon |
| I have not used that particular VFD, but a 2 pole motor runs at twice the rpm of a 4 pole on the same frequency. There should be a base motor set up in the VFD parameters. A two pole motor runs at 24000rpm on 400hz, a 4 pole 12000rpm. Yours should be set for 2 pole. Al.
| On most VFD's you can set the display for various readouts, such as frequency, rpm current etc. Try setting it to Frequency and see if it is 400hz? Al.
| Thanks Al, I found the answer to my question here. http://www.woodworkforums.com/f170/t...d-users-96380/ Here are the settings that are factory default. PD010 = 6.5 (Min Voltage) PD144 = 1772 (Rated motor Revolution) I changed these as follows PD010 = 8 PD144 = 3000 8 x 3000 = 24000 RPM My VFD now shows 24000 RPM and sounds more like what I expected. |
| I will have to book mark that one! Glad you got it going. Al.
| Need Help!- Help Help Help - Huanyang VFd and spindle | PsychoPig7 | Phase Converters and VFD | 7 | 12-04-2011 09:19 AM |
| Problem- Huanyang HY02D223B goes POP! | stevespo | Phase Converters and VFD | 1 | 09-26-2009 02:12 PM |
| CNC Shows? | tmreitz | Trade Shows and Events | 10 | 09-25-2007 12:27 PM |
| SME Shows | MBG | Trade Shows and Events | 1 | 09-07-2005 09:53 PM |
| Are their any shows | CNCadmin | Trade Shows and Events | 3 | 03-29-2003 09:39 PM |
