| Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion |
Im looking at manufactured RPCs and on starting load charts like easy, medium, and hard starts they have lathes as hard starts and was wondering if a large lathe with a clutch would be still be considered a hard start? Seems like with the motor starting with the clutch disengaged it would be an unloaded start? |
| I see nothing wrong with your logic. If the clutch is disengaged when the motor starts it is an unloaded start. You must have a manual lathe with a clutch. In my experience this is not very common which could be why the RPC companies list lathes as a hard start.
| Its still regarded as a hard start up to three times the motor rating. ie a 3hp can be like starting a 9hp. I do have a 240V single ph 1 1/2hp lathe with a clutch, blows a 13A fuse 1 in every three startups. Likewise the other lathe M300 with 3hp 3ph 400V needs a 10HP inverter. A 5.5hp inverter lasted 1 1/4hrs that could supposedly handle 150% of rating for 30 secs. |
| If it is just one dedicated machine, have you considered a VFD? Al.
| Obviously this is not right and we would all like to know the brand for our own reference...... hope u returned it and got a full refund.... |
| The difference is though Mike it was wired plug and play, not direct to the motor with no controls which it was quite happy doing on a 3 sec soft start. Teco MA7200 Now running the MA7200 7.5kw plug and play via the contactors. |
| Problem- question about electric motor starting up on lathe | ryansuperbee | General Metalwork Discussion | 2 | 09-09-2009 09:14 AM |
| Slant bed lathe Z axis 4 way load rails? | will gilmore | Vertical Mill, Lathe Project Log | 3 | 03-06-2009 04:22 AM |
| Need Help!- STarting NEw project - Need Serious Help to Understand PArts before starting | osix | DIY-CNC Router Table Machines | 2 | 06-30-2008 03:54 PM |
| Z load on vf-3 | mls | Haas Mills | 5 | 05-15-2008 10:54 PM |
| Just starting to look... | neeboy | DIY-CNC Router Table Machines | 2 | 03-16-2008 07:56 PM |
