Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 07-17-2011, 03:05 PM
Vegabond's Avatar
Vegabond is on a distinguished road
Red face Can`t turn on my chineese the spindle from Mach3..
Hello.
i have tryed to install mach3 and install the huanyang plugin...
I have activated it in mach3, and set the correct COM port...
The PD001/PD002 is 99 instead for 2.. some tip that i can try to fix it?
Greetings from Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
Old 07-17-2011, 03:13 PM
Vegabond's Avatar
Here is the error...
Robert.
Need Help!- mach3 turn +vfd+cnc4pc spindle card (c6) still not gettings rpms by s word jasminder Mach Lathe 2 02-24-2011 01:20 PM
Solidcam with mach3 turn Rik H SolidCam 0 02-04-2011 11:41 AM
mach3 turn simulation? tracebender Mini Lathe 2 02-23-2010 02:57 PM
Set Home on Mach3 Turn scot1972 Mach Lathe 1 03-12-2008 01:46 AM
Turn off the system beep in Mach3? fatal-exception Mach Mill 0 09-19-2007 02:20 PM
