Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 06-01-2011, 08:38 PM
ceencee is on a distinguished road
Dual 5 hp spindles
I am a complete newb when it comes to the inner workings of a cnc but this build is going well with all your help. My next question which is probably an easy answer is can 1 vfd control 2 spindles or is it a 1 for 1 deal. All the sites dont say so im thinking its a one vfd per spindle deal. Any insight would be appreciated so we can continue on on our wiring schematics and get this router figured and built.
Thank you
Old 06-01-2011, 09:00 PM
ger21's Avatar
Do you mean two at the same time, or only one at a time?
At my last job, our machine used one VFD for two 10HP spindles, with relays or contactors switching between the spindles. Only one was used at a time.
I don't know enough to tell you how to do it, though.
Old 06-01-2011, 09:15 PM
Thanks Ger21
The spindles will be used separately so I'm thinking with some creative use of relays it can be done. If any one has any idea what this creative use of relays is, lol I would sure like to pick your brain.
Wade
Old 06-01-2011, 09:46 PM
ger21's Avatar
You might want to use a PLC to control them. You need to be 100% sure that relays don't get switched under power, or both spindles get power together, or sparks may fly.
Old 06-01-2011, 10:05 PM
I am using a PLC to control the multi drill spindle block so i should be able to add some controls for the spindle power and controls for the pneumatics that drop the spindle that is in use. I hope that those PLCs are easy to program.
Now these are 2-5 hp colombo spindles, do i get a 5 hp VFD or do I go a little larger for performance issues.
Wade
Old 06-01-2011, 10:39 PM
Al_The_Man's Avatar
If using a PLC it will be relatively easy to program the logic so that either motor contactor is picked up or dropped out only when the VFD is at zero speed, usually the VFD outputs are customizable on most.
I did have one application where both double ended lathe spindles were picked up by one VFD.
Old 06-02-2011, 06:47 PM
mike_Kilroy is on a distinguished road
Originally Posted by ceencee View Post
Thanks Ger21
Wade
yep, just put a 3 phase contactor (relay) in series with each motor. then wire both of these to the vfd output. As AL said, u must be sure your PLC logic does not change either relay while vfd has output; best to interlock to only sw one or the other one on when 3 ph power to the vfd is OFF.
no oversize of vfd required. just make it a 5 hp model.
Emco 420 going threw the cog belt that drives the dual main spindles, every month. ameyer EMCO Lathe 0 04-18-2011 06:11 PM
Any reasonably priced (cheap) spindles other than the chinese spindles? HereinCS DIY-CNC Router Table Machines 7 07-30-2010 11:58 AM
Dual Steppers or Timing Belt for Dual X-axis? GEBrown Linear and Rotary Motion 3 05-27-2010 11:45 AM
Spindles de alta qualidade.High quality spindles. Newtron Product Announcements & Manufacturer News 0 09-21-2009 02:33 PM
Good article on dual contact spindles/toolholders Belding General Metalwork Discussion 1 11-11-2008 03:27 AM
