Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 05-30-2011, 10:22 AM
Alphonsus is on a distinguished road
Unhappy TB6560 driver x VFD
I have a chinese TB6560 driver board and would like to control my VFD (turn the spindle on/off and change its speed) by software. The board has a spindle control/relay but the "manual" has no information on how to use it.
I've contacted the seller, but, he couldn't even understand the question
Have you ever used this function or know how to do it?
What would you suggest?
Old 05-30-2011, 02:05 PM
doorknob's Avatar
doorknob is on a distinguished road
Do you have one of the blue, 4-axis or 3-axis boards?
In the first post of the thread at http://www.cnczone.com/forums/genera...y_chinese.html, there is an attached file named schematic_controller_TB6560.zip‎ that contains schematic diagrams for a 4-axis board (you should double check to make sure that your board is wired in the same way as the OP's board). If you unzip that file and look at Slide01.JPG, Slide02.JPG, and Slide03.JPG, you can trace out the wiring for the spindle relay control.
It looks like pin 2 of the DB-25 connector is used for spindle control. I'm not sure from the schematic whether that pin is "active high" or "active low", but it should be easy enough to test. A "high" (+5 volt) signal on that pin will probably energize the relay "RLY61", but if not, then a "low" (0 volt) signal on that pin should do the trick. The spindle relay input line should also be present at pin 10 of the DB-15 accessory connector (but if you want to control the spindle from Mach3 or other software, then you would probably use the DB-25 input instead of the DB-15 input).
It looks like 2 relay contact pins are taken to an output connector on the board (the 4-pin green connector on the edge of the board, close to the black relay). The other two pins of that connector are supposedly connected to ground. I do not know what the relay output contact current or voltage rating is (but maybe that is printed on the relay itself).
As far as I know, the blue Chinese TB6560 driver boards do not have the capability of putting out a variable control voltage to set the VFD spindle speed. Some other drivers (such as the Geckodrive G540_ have a 0 - 10 volt analog output for that purpose.
Old 05-30-2011, 05:39 PM
Thanks, doorknob!
Mine is 5axis blue one, very similar to lasik2025's one.
I´ve just downloaded the file and will study the schematics before trying something. Thank you!
Tags
tb6560 vfd spindle
New (red version) of TB6560 chinese driver board hspalm Stepper Motors and Drives 17 04-30-2012 01:04 PM
TB6560 3-axis driver from ebay kish89 Stepper Motors and Drives 10 06-30-2011 07:10 PM
Need Help!- TB6560 4 Axis CNC Motor Stepper Driver 3A 12-36V vicsrc Want To Buy...Need help! 0 03-10-2011 10:57 AM
need help with 3 AXIS (TB6560) CNC DRIVER BOARD Jason Miller General Electronics Discussion 34 01-06-2011 12:25 PM
TB6560 3-axis driver manual control kish89 Stepper Motors and Drives 4 12-08-2009 03:19 PM
