Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 04-28-2011, 03:59 PM
rrbmachining's Avatar
rrbmachining is on a distinguished road
Delta VFD Drive
We have a 3 phase drive type Delta VFD075B-023A which is a 230v 3 phase type for US supplies. Our supply here in the UK is 415v 3 phase. So this drive will not work on our supply. The machine supplier (Lehigh) have told us to wire the machine for 230V single phase and assure us the Delta drive will work fine. Has anyone got this type of set up running. We dont want to blow up another VFD drive. Any help would be appreciated
Old 04-28-2011, 04:44 PM
Al_The_Man's Avatar
Check the manual, it will say if it accepts single phase or not, most do now up to 5hp~7.5hp.
Al..
Old 04-30-2011, 08:28 PM
ihavenofish is on a distinguished road
the deltas only support single up to 3hp if i remember. the manual should be available online. i had a 1.5hp delta vfd on 220 single. basically you just connect 2 wires instead of 3 to the power input.
Delta VFD -E help woodguy60 Phase Converters and VFD 1 03-19-2010 10:47 AM
Delta Tau Anyone Al_The_Man General CNC (Mill and Lathe) Control Software (NC) 21 01-14-2010 01:08 PM
Delta Tau cnc-it General CNC (Mill and Lathe) Control Software (NC) 3 04-29-2008 11:07 PM
delta 40 rhurt Tree 0 03-24-2007 10:33 PM
Wye-delta, delta-wye configurations? mackeym Phase Converters and VFD 10 09-27-2006 05:02 PM
