Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Phase Converters and VFD
Phase Converters and VFD Running 3 phase machines on single phase power and variable frequency drive discussion
Old 04-24-2011, 06:24 PM
Jackal66 is on a distinguished road
Help Selecting VFD
I have been looking at VFDs and am somewhat undecided.
My machine will be using Mach 3 to control the spindle.
The spindle motor is : 2.2 kw, 240 volt, 8.5 Amps.
The ones found on Ebay are almost all from China. ( The others maybe ,too, and they just don't advertise it???)
Here is the best prices I have found on *Name brand* VFD's:
Teco Westinghouse Drives, Power Components, Teco FM50 Phase Converter, Teco Inverter
The (2) that caught my interest are :
3HP 230 Volt -- USE AS A PHASE CONVERTER PLUS GET VARIABLE SPEED, Model FM50-203-C, Single Or Three Phase Input-Three Phase Output, variable frequency drive, variable frequency drives, ac drive, vfd, afd, frequency drive, drive, inverter, adjustable
And :
3HP 230 Volt -- USE AS A PHASE CONVERTER PLUS GET VARIABLE SPEED, Model JNEV-203-H1, Single Phase Input ONLY, Three Phase Output, variable frequency drive, variable frequency drives, ac drive, vfd, afd, frequency drive, drive, inverter, adjustable sp
Would these be ok, is the difference between the two something needed over the less expensive one? Would a larger 5HP be better ?
Is there another on the main page that would suit my application better?
These brands are just names that I am familiar with. They may not be a good selection for a VFD. If so please advise me of this also.
Thanks in advance,
JAckal
Everything is bio-degradable, if you run over it enough times with the lawnmower.
Old 04-24-2011, 08:33 PM
Al_The_Man's Avatar
The second one is described as Sensorless Vector, hence the higher price.
This is the preferable one.
Old 04-25-2011, 12:16 AM
TarHeelTom is on a distinguished road
Here's another VFD source
Variable Frequency Drive, AC Motor Drives, Pool Pump Motors, Marathon Electric 3 Phase Motor, Teco Westinghouse Distributor
Tom
Old 04-25-2011, 09:06 AM
Thanks Guys,
Tom, I think that might be the same company but on a different page. They are the lowest prices I've seen on brand name stuff.
Is one of the brands better than the other? Teco, Westinghouse, etc?
Is it better to go with a larger unit ( 5hp) , or would that not work correctly?
Thanks again,
JAckal
Old 04-25-2011, 09:12 AM
Al_The_Man's Avatar
Many VFD manufacturers now offer 1 ph or 3 ph without derating on 1ph.
It looks like the ones in the link are this type, you can use a larger VFD, but if the manuf says it will support the FLA of the motor you have, you should be OK.
Help with selecting stock Astroguy Rhinocam 2 12-23-2010 08:15 AM
Need Help!- v23 not selecting geometry lynn mynatt BobCad-Cam 0 09-24-2009 01:31 PM
Help with selecting CAM software mgandy02 General CAM Discussion 4 08-28-2009 01:39 PM
selecting the right router endgrainguy DIY-CNC Router Table Machines 6 06-13-2008 11:44 AM
Need help selecting CNC jachyra Want To Buy...Need help! 1 01-12-2008 06:10 PM
